samsung RF265ABBP French Door ice build up.
4 replies to this topic
#1 benzonaruckus
benzonaruckus
  • Chief Appliantologist
  • 19 posts
  • Flavorite Brew:no time, work and go to school 24-7. when i do, anything cold.
Posted 30 March 2012 - 09:59 AM
Hi, I once again have another samsung refrigerator. The complaint was the refrigerator side was at 50+ degrees F and so after I get there and pull the back off I find the fan blocked with ice and a massive chunk of ice built up on the top right corner above the evap coil. The Bimetal checked out okay and the defrost element but I was unsure of the reading on the sensor and at the time did not have a way to get it into defrost mode. The rest of the evap coil had a nice even pattern for frost and the freezer was working great(-6 degrees F) I'm a little stumped. I was unsure if it was a defrost issue as the whole coil hadn't really been frosted up but really only the top layer and the suction line area on the evap coil at the top.
Your help is appreciated
Matt
Edited by benzonaruckus, 01 April 2012 - 10:18 AM.
#2 certified tech group 51
  • 2,639 posts
Posted 30 March 2012 - 10:52 AM
Don't do too many Samsunk's, but, If a pict of the offending evap coil could be posted........We could all 'tune in'....... :buddha:
    Shōgun
  • Master Samurai Tech
  • 30,170 posts
Posted 30 March 2012 - 09:59 PM
Could you double-check that model number?
Also, is this a double evaporator unit?
#4 benzonaruckus
benzonaruckus
  • 19 posts
Posted 01 April 2012 - 10:30 AM
Yes it is a double evap unit. and the model was RF265ABBP/XAA sorry:(
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 April 2012 - 11:48 AM
this may be your service manual
RF267A RF26XA SERVICE MANUAL.pdf
link PM'd
