Fisher paykel IWL16 Washer - high suds problem
Fisher Paykel IWL16
14 replies to this topic
#1 ironbrewer
ironbrewer
  • 9 posts
  • Flavorite Brew:That is like asking who your favorite child is
Posted 31 March 2012 - 08:18 AM
I have a
Fisher Paykel
IWL16
Washing machine
3 years old
That has a high suds alarm every time we use it. We have tried running it with no detergent and still get it. I'm wondering if it is a sensor or some easy fix I can do. We have been using it for 3 years and have not changed detergents or changed amounts we use.
Any help would be greatly appreciated
Jim
#2 RegUS_PatOff
  • 30,272 posts
Posted 31 March 2012 - 10:19 AM
... running it with no detergent and still get it.
are there still suds visible ?
#3 ironbrewer
ironbrewer
  • 9 posts
Posted 31 March 2012 - 03:33 PM
No suds are visible.
#4 ironbrewer
ironbrewer
  • 9 posts
Posted 31 March 2012 - 05:10 PM
Ok I just tried to run it again with no detergent and got a fault code. It did the following
1 eco active
2 sensing water level
3 Sensing fabric type
4 started agitating 48 min
5 Rinse 1 at about 36 min
6 got down to 7 minutes and then reverted to rinse 1 38 min
Then it started beeping and gave me a fault code 37.
Thanks for any help
#5 RegUS_PatOff
  • 30,272 posts
Posted 31 March 2012 - 07:53 PM
37 Pump blocked
#6 ironbrewer
ironbrewer
  • 9 posts
Posted 31 March 2012 - 10:11 PM
Figured out the code. Its a blocked or non working pump. Hopefully I'll be able to work on it tommorrow.
#7 DADoESTX
DADoESTX
    Kohai
  • 260 posts
  • Flavorite Brew:Iced tea with a spike of earl grey
Posted 01 April 2012 - 12:52 PM
A blocked pump code doesn't necessarily mean the pump is the problem. The machine does not monitor the pump directly, but rather indirectly by way of whether the water level sensor indicates the water is draining (water level goes down) when it's supposed to be draining. A bad or clogged recirculation valve can cause the problem by getting stuck in recirculation mode, which will prevent draining even if the pump is perfectly fine.
#8 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
  • Flavorite Brew:Blue Moon or Lion Imperial or Shiner Bock
Posted 01 April 2012 - 02:20 PM
Check your drain line for obstructions. I put a unit back into service that was displaying a similar issue by opening the drain line and watching a dime fall out.
#9 ironbrewer
ironbrewer
  • 9 posts
Posted 02 April 2012 - 03:23 PM
Ok I pulled out the pump. It was rotating easily, but was clogged with junk. I cleaned it out. The unit is going to rinse 1 and staying there. It soulnds like there is water flowing for the rinse. After quite a while the unit said high suds again. There were some suds still there, but not a lot. any ideas. It is not full of water after the high suds alarm, so I believe the pump is now working.
1 eco active
Thanks for any help
#10 ironbrewer
ironbrewer
  • 9 posts
Posted 02 April 2012 - 06:54 PM
Ok I ran it again with no soap and it still ended up saying that the suds were high. There were no suds.
Any ideas??
#11 ironbrewer
ironbrewer
  • 9 posts
Posted 03 April 2012 - 12:29 PM
Everybody loves error code 37 because its easy, but the high suds with no suds seems a bit tougher.
As the crickets chirp.
#12 DADoESTX
DADoESTX
    Kohai
  • 260 posts
Posted 03 April 2012 - 01:11 PM
I've *never* had an oversuds situation on my GWL08 or IWL12 so am not knowing (have not directly observed) how oversudsing is detected.
Suggestions: Pull the inner basket and make sure the tub opening to the pressure dome is not clogged. Clean any debris/residue from the drive shaft and cog, make sure the basket moves freely up/down on the drive shaft to engage and disengage the cog.
#13 ironbrewer
ironbrewer
  • 9 posts
Posted 03 April 2012 - 01:15 PM
How do you pull the inner basket??
#14 ironbrewer
ironbrewer
  • 9 posts
Posted 03 April 2012 - 10:33 PM
I found the problem. Even though it said high suds and not error37, I still kept pulling hoses. It ended up being the outlet hose of the pump was clogged. I found a penny and some lint. It seems to be working fine now.
#15 Samurai Appliance Repair Man
  • 24,333 posts
Posted 05 April 2012 - 11:05 PM
Domo for posting what you found, ironbrewer! :)
Also tagged with one or more of these keywords: Fisher Paykel, IWL16
