Frigidaire Dryer model LEQ1442ESO beeps then shuts off after about 20 seconds.
LEQ1442ESO Frigidaire Dryer beeps error code help
2 replies to this topic
#1 MikeandDori
MikeandDori
  • 4 posts
Posted 01 April 2012 - 09:34 AM
The lights blink in a 6-2 pattern. The row of lights on the right blinks 6 times while beeping, then the start light blinks twice.
I can't find a repair manual online. Can you tell me what the 6-2 code means?
~Dori
#2 RegUS_PatOff
  • 30,232 posts
Posted 01 April 2012 - 11:27 AM
... The lights blink in a 6-2 pattern. The row of lights on the right blinks 6 times while beeping, then the start light blinks twice.
the five indicator lights of Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit
and the START indicator light will flash the number of times for the second digit.
soo... are you saying the 5 lights blink (i6) times
and the Start Light actually blinks a total of (8) times ?
68 = Key (button) Struck Fault
One of the keys (buttons) is stuck closed (active).
FUNCTION TEST SEQUENCE
1. Position cycle selector to 12 O’clock position.
2. Press and hold Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold Pause Cancel and START buttons simultaneously for 4 seconds.
The control will enter test mode, the buzzer will sound 3 times and all LED’S will rapidly flash.
After entering the test mode, the program knob can now be rotated to select the following tests:
4 O’clock: Drive motor runs; heat source is off.
Key test:
a. When the TEMP key is pressed, all the TEMP LED’s should light. If the TEMP selector is the rotary knob, and the knob is rotated, there should be a key beep with each setting.
b. When the DRYNESS key is pressed, all the dryness level LED’s should light.
c. When the OPTION or Select key is pressed, all the Option LED’s should light.
d. When the START key is pressed, all the cycle status LED’s should light.
e. When the Pause Cancel key is pressed, all the cycle status LED’s should light.
#3 MikeandDori
MikeandDori
  • 4 posts
Posted 01 April 2012 - 01:13 PM
Exactly... the 5 lights blink (6) times
Thanks so much for your help! I'm so glad this was an easy fix. All's fine now.
~Dori
0 members, 1 guests, 0 anonymous users
