wagonburner
GE Adora washer WHDVH626F0WW - water will not enter the washer
7 posts in this topic
i have a ge adora front loading washing machine. when turned on it will spin a couple times to left then to right. the door will unlock then a couple seconds later the door will lock again. then it will start making a humming noise. no water coming into tub. even tried to run on rinse spin cycle same thing. have cleaned the filter and unplugged washer then plugged back up same thing. any clues
Sounds to me like it's not getting any water.
Check to make sure the water is turned on, if it is turn it off and pull the hoses and checks for water valve screens plugged with debris.
Also make sure you don't have those funky flood-safe hoses which may have activated and blocked water flow.
my bad the model # WHOVH626FWW
i am trying to run diagnostic codes on washer following the tech manual but cannot get into error codes . it takes me to t01 then i can set what model then i can not get to error codes t02 . ge adora model # WHDVH626
I ordered the water inlet valve from RepairClinic and that fixed the problem: Water Inlet Valve
Water-Inlet-Valve-WH13X10023-00767218.jp
Thanks!
