Kitchenaid KGRI801PBL00 oven temp overheat
16 replies to this topic
#1 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 01 April 2012 - 10:03 PM
Greetings Appliantologists,
I'm not all that savvy with electric/gas things, but here is the problem:
Turn oven on, set temperature to 350. Display stops @ 348 during preheat, but oven takes off into stratosphere, I put a temp gauge in the oven and it registers 550. I've seen a lot of the OPPOSITE issue showing on the boards.
Tried unplugging the unit, same thing.
Self clean was run prior to this (ducks. I read the FAQs :)
A local appliance tech replaced the temp sensor, same problem. He said the electronic control panel needs to be replaced together with the thermostat, for $650. I of course can buy a new one for less than that.
Internet is my best friend. There are no error codes when you start up the oven, I figured out how to get into the diagnostics, and all the error codes show 0111 (normal methinks) except the third code shows 01rr, I dont know what that is, but I'm not seeing the E or F codes come up. I am therefore suspicious of the diagnosis, and I'd rather not plunk down $$ :)
I dont have the diagnostic tools to check current, etc.
Thanks for your help
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,616 posts
Posted 01 April 2012 - 10:27 PM
Your problem can be caused by one of two things, sensor probe and/or main board (unless its some gas thingamabob of which I am not an expert.) Order parts from repair clinic and you can return them if they do not fix the problem. When you get the parts, shut off power to stove, access board and/or probe by removing panels. Take lots of pictures and replace parts. ..with board, replace one wire at a time. Now if you don't take pictures, don't come back here asking where the red wire goes.
So you ran self clean, eh? No need to duck now, we are very patient. As soon as you stop ducking, we will hurl all manner of things at you.
Edited by DurhamAppliance, 01 April 2012 - 10:33 PM.
www.DurhamApplianceThrift.com
#3 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 01 April 2012 - 10:32 PM
If the temp probe is good then its control issue as far as the thermostat goes I don't know y he would want to change it? I would start with control!!! Look behind back panel for tech sheet for test procedures
Edited by Derik, 01 April 2012 - 10:33 PM.
#4 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 01 April 2012 - 10:34 PM
You mean the control board or the oven back panel?
#5 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 01 April 2012 - 10:42 PM
I assume you mena control test board procedures
#6 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 01 April 2012 - 10:44 PM
I'm betting it's a control brd issue and tech sheet should be behind back panel behind range at the top!! Check it out Also betting problem came from self-cleaning oven!!!!! Not good idea temps reach up to 1000 degrees, wastes lots of gas shortens life of ignitor and causes lots of control brd failure, oh and did I mention doesn't clean worth a crap!!!!!!
Edited by Derik, 01 April 2012 - 10:46 PM.
#7 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 01 April 2012 - 10:52 PM
Contrl brd #4453936bl check it out at repairclinic you can't go wrong especially from someone wanting to just change all possibilities instead of properly diagnosing!!!!!
#8 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 01 April 2012 - 10:55 PM
I found some diag routines on the web for this too.
I didnt know about the self clean problems until I read the FAQ. My old house had a real old "manual" electric oven, and we beat the crud out of it, AND IT NEVER BROKE DOWN!!!!
Interesting note - I have a GE oven too, the control board is located above and behind the oven body, but the kitchenaid is right in front, so it definitely gets beat up by the heat a LOT more
I am going to price out the panel on your site, and see how log it would take me to do it. With Passover on the way though, I may not have enough time to do this.
I really appreciate your responses, it is very kind of you all to help us netizens out.
#9 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 01 April 2012 - 11:07 PM
out of stock! Plus, I gotta figure out how to get that front panel off
#10 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 01 April 2012 - 11:25 PM
Arnt there screws holding left and right end caps on and couple screws under control if u look up when oven door opened??
Edited by Derik, 01 April 2012 - 11:25 PM.
#11 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 01 April 2012 - 11:33 PM
yes, I got them out, it's loose now but I cant seem to get it off that flange along the top
#12 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 01 April 2012 - 11:41 PM
Post a pic you might have to take off burners and lift top to acess other screws can't remember!
#13 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 01 April 2012 - 11:46 PM
ok, i will pik up on this tomorrow evening. Thanks for the advice
#14 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 April 2012 - 01:37 AM
4453936BL is the Control Panel # 1
you may need Electronic Control # 3
9760009
http://www.repaircli...R=154&N=1182081
#15 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 03 April 2012 - 08:59 PM
Sorry was on wrong pic!!!!!
#16 RussTech
RussTech
    Kohai
  • Chief Appliantologist
  • 309 posts
  • Flavorite Brew:Heineken
Posted 04 April 2012 - 07:48 PM
I don't think you can buy that range for less then 650 bucks at all. In fact anything remotely similar from KA is running 1100 bucks no problem.
Edited by RussTech, 04 April 2012 - 07:51 PM.
#17 Nachum Hurvitz
Nachum Hurvitz
  • 8 posts
Posted 25 April 2012 - 10:30 PM
I spent a LOT of time trying to get that front panel off, and then discovered that I have to basically disassemble the oven to get to the board you mentioned. I was pretty much spending multiple evenings trying to do this at the expense of family time. As a GE employee (not appliances), I got an excellent deal on a comperable clearance oven.
Thank you for the help.
