Removing the hub nut on a Maytag SAV2655AWW washer
25 replies to this topic
#1 ndpeters
ndpeters
  • 12 posts
  • Flavorite Brew:Anything with caffeine
Posted 02 April 2012 - 09:39 AM
I am trying to replace the triple lip seal and bearing on my "Maytag" SAV2655AWW. I am stealing another forum members pic because I am at the office and not near the pile of parts that is my washer right now. Anyway, I have a spanner wrench, but I cannot remove this part:
I removed the bolts and the inner tub but I cannot get the hub to break loose, any suggestions?
#2 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 163 posts
  • Flavorite Brew:guiness
Posted 02 April 2012 - 11:24 AM
your'e using the round insert to the wrench that fits over the splines?
#3 ndpeters
ndpeters
  • 12 posts
Posted 02 April 2012 - 11:40 AM
No. It will not fit that way...
#4 RegUS_PatOff
  • 30,242 posts
Posted 02 April 2012 - 12:52 PM
... I have a spanner wrench, but I cannot remove this part:
this one ?
http://www.repaircli...sp?R=154&N=1590
#5 ndpeters
ndpeters
  • 12 posts
Posted 02 April 2012 - 12:54 PM
this one ?
Sort of like that one...
This is the one I am using...
#6 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,467 posts
  • Flavorite Brew:Killians Red
Posted 02 April 2012 - 03:01 PM
Wrong wrench ...wrong insert...
#7 ndpeters
ndpeters
  • 12 posts
Posted 02 April 2012 - 03:27 PM
Not using the insert, the wrench fits the slots. Can I use something instead of the spanner wrench?
  • 24,287 posts
Posted 02 April 2012 - 05:13 PM
You could try using the correct spanner wrench that Grand Master Reg linked you to. If not, you're left with just spit and determination. :argh:
#9 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,467 posts
Posted 02 April 2012 - 05:37 PM
I don't believe that is the right one either ,Boss...I will see if I can locate the correct 'un...
Item# 455550 is the insert...didn't see the spanner wrench that fits it...hmmm...
Found it! Item #535997...discontinued? NLA? Not sure what you use in its place.
Short of this, you can use a screwdriver to split it and then replace it, if ya can't get it loose.
Edited by KurtiusInterupptus, 02 April 2012 - 06:33 PM.
#10 ndpeters
ndpeters
  • 12 posts
Posted 02 April 2012 - 07:06 PM
Split which part???
I think I am going to call a pro...
#11 kdog
    RoughShod
  • 7,428 posts
Posted 02 April 2012 - 07:28 PM
Just put the spanner down onto the metal collar and bang away, the plastic nut will come with it - broken or not it gets discarded anyhow as the new tubnut has it integrated - see pic below:
http://www.repaircli...mber=SAV2655AWW
Tub-Seal-and-Bearing-Kit-21002237-010253
#12 ndpeters
ndpeters
  • 12 posts
Posted 02 April 2012 - 10:11 PM
Perhaps I could keep banging away. spent an hour beating the spanner with a hammer yesterday and it would not budge.
#13 RegUS_PatOff
  • 30,242 posts
Posted 02 April 2012 - 11:47 PM
just for the record ...
these later model Maytags have "normal" right-hand threads..
lefty-loosy, righty-tighty
#14 ndpeters
ndpeters
  • 12 posts
Posted 03 April 2012 - 07:41 AM
Damn.
#15 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,467 posts
Posted 03 April 2012 - 07:47 AM
nice shootin' master reg! No more calls please, we have a winner!
#16 ndpeters
ndpeters
  • 12 posts
Posted 03 April 2012 - 09:10 AM
The hub will not budge either way. Do I need to keep the transmission from turning as well? It seems that as I hit the hub it turns and the transmission turns with it, I hope that makes sense...
#17 sh2sh2
sh2sh2
    Sōhei
  • 212 posts
  • Flavorite Brew:yeunling
Posted 03 April 2012 - 09:56 AM
yes, if you follow the instructions that came with the kit it tells you how to use a vice grip to hold the transmission against the milk stool
#18 ndpeters
ndpeters
  • 12 posts
Posted 03 April 2012 - 10:15 AM
Damn. Another tool to buy...
#19 sh2sh2
sh2sh2
    Sōhei
  • 212 posts
Posted 03 April 2012 - 12:17 PM
no special tool just a normal vice grip or some sort of clamp, anything to lock the tranny in place
#20 ndpeters
ndpeters
  • 12 posts
Posted 03 April 2012 - 01:04 PM
Woo hoo! I have a large c-clamp that might work.
