denlang
kenmore series 80 gas dryer model # 110.70852990
3 posts in this topic
I took dryer apart:), heating element was not glowing:(, changed with new one:). Still no glow:X. What do i check next.:(
Assume you meant you replaced the glow coil, the igniter??  If the igniter will not come on check the thermofuse first, reference # 39 in this breakdown...this opens if the air flow is blocked from the dryer thru your dryer vent system so  check your air flow to the outside if this fuse is bad...
