Maytag Dryer LDE8414ACE won't turn with an actual load
9 replies to this topic
#1 davet
davet
  • 4 posts
  • Flavorite Brew:Guinness
Posted 03 April 2012 - 09:45 PM
Hello,
My dryer recently had an issue with a a bad drum roller. I replaced both rollers and while I was at it, I opted to replace the belt as I didn't want to have to drive across town again anytime soon. After a few iterations, I believe that I have the belt threaded properly and the drum turns smoothly by hand or when I turn it on. The catch is that as soon as I actually put even a small load of clothing in, it fails to turn ... or struggles to turn ever so slowly.
I'm wondering if I need more tension on the belt and if perhaps I need a need idler pulley?? I think I can pound out the dent from my skull beating against the side of it easily enough. :-)
Thanks!
#2 RegUS_PatOff
  • 30,688 posts
Posted 03 April 2012 - 10:07 PM
does this Maytag Dryer have a model number ?
#3 davet
davet
  • 4 posts
Posted 03 April 2012 - 10:11 PM
Sorry, LDE8414ACE
Thanks!
#4 davet
davet
  • 4 posts
Posted 03 April 2012 - 10:23 PM
More information ... I tried a really light load and found that it runs great for maybe 2 minutes and then it's as though there just isn't enough torque to turn the drum. The motor continues to hum and there is heat, but the drums stops turning.
#5 john63
john63
  • 1,411 posts
On the DRUM---there's a slight groove/recessed spot (near the center of the drum)
Most likely when the belt was installed---it's in this groove on the drum.
Remove the FRONT COVER of the dryer (unplug first)
Using a flashlight---examine the belt on the drum. If the belt is in the "groove"---re-position the belt by turning/rotating the drum CLOCKWISE. Use your fingers to push the belt rearward & out of the groove.
Test dryer
Edited by john63, 03 April 2012 - 10:43 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
  • 24,694 posts
Posted 03 April 2012 - 10:24 PM
Sorry, LDE8414ACE
Thanks!
Topic title edited.
#7 davet
davet
  • 4 posts
Posted 03 April 2012 - 10:35 PM
Thank You Very Much! This was exactly what the problem was.
#8 RegUS_PatOff
  • 30,688 posts
Posted 03 April 2012 - 10:39 PM
Diagram E
Belt Style: Flat Belt with ribs
Flat side of belt against drum
#9 john63
john63
  • 1,411 posts
Posted 03 April 2012 - 10:45 PM
:thumbsup:
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#10 Derik
Derik
    Sōhei
  • 227 posts
  • Flavorite Brew:coors light
Posted 04 April 2012 - 12:16 AM
Nice shootin john63!!!
