Electrolux dishwasher EIDW6105GB1
WILL NOT START
6 replies to this topic
#1 rolandvz71
rolandvz71
    Sōhei
  • Chief Appliantologist
  • 202 posts
  • Flavorite Brew:Sweet Sun Tea w/lemon
Posted 04 April 2012 - 12:06 AM
Ok I found this on Craigslist for 40 bucks and my of school of hard knocks continues.....Figured 40 bucks to learn something new? The return is priceless!
I put water to it
I wire up electricity
I open up the door I get a BLUE light on the normal cycle then it turns off when I close the door
I press the start button and I get nothing.....I try all the cycles and still i get nothing...no lights, no sounds---- nothing
Tested door switch is GOOD
Is there any diagnosis /sequence of buttons I can uses to test out other components?
Thx!
Edited by rolandvz71, 04 April 2012 - 12:39 AM.
#2 RegUS_PatOff
  • 30,708 posts
Posted 04 April 2012 - 12:35 AM
also has low 12v DC switching power supply
wiring diagram 154676603.pdf
link PM'd
#3 RegUS_PatOff
  • 30,708 posts
Posted 04 April 2012 - 12:42 AM
parts manual :woot:
5995514824.pdf c.2008
#4 kdog
    RoughShod
  • 7,433 posts
Posted 04 April 2012 - 12:47 AM
The board on that machine is located behind the kickplate and has led's built into it to show fail codes - it"s a real nasty design - check the manual in the PotLuck Supper - http://appliantology...lux-dishwasher/
#5 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 04 April 2012 - 12:51 AM
thx for the doc! I will report findings in coming days....
#6 rolandvz71
rolandvz71
    Sōhei
  • 202 posts
Posted 05 April 2012 - 12:29 AM
OK back w/a update.....it was good to have all the documents you guys gave me (a plug for future members)
This site is really amazing--- you get the help you need in a matter of minutes!
Well it was operator error on my part and probably the fella I bought this from also, because there is not a dang thing wrong with this dishwasher!
You must select your options w/the door OPEN then close the door and press START....I was doing the opposite! (manuals I did not have but they were provided by the fellas from appliantology.org so I was able to get a running start!)
So I ran a cycle and sure enough she fired right up!
:thanks: for all the help!!!
#7 RegUS_PatOff
  • 30,708 posts
Posted 05 April 2012 - 02:16 AM
see PDF page 5
To start, press START/CANCEL pad and close door. :blink:
EIDW6105GB1
Use & Care Guide
154671201b.pdf
Also tagged with one or more of these keywords: WILL NOT START
