FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
Bosch Front Loading Washer WFM3200UC pump help
2 replies to this topic
#1 jwatson876
jwatson876
  • 1 posts
  • Flavorite Brew:Killian's
Posted 04 April 2012 - 07:02 AM
The washing machine won't drain. I took off the pump access or whatever you want to call it and drained all the water manually, there wasn't anything clogging it that I could find. I poured a cup of water backwards through the drain hose to make sure it wasn't magically blocked somehow and the water came through that just fine. I did notice that the pump seemed to be making a lot more noise than usual, but I could be crazy. I took a picture of it, that little dirty white thing in the back spins and makes the noise. Any help is appreciated!Posted Image
#2 kdog
    RoughShod
  • 7,465 posts
Posted 04 April 2012 - 07:55 PM
Check out this Podcast
Link to Pump if needed: - would that model number be wfmC3200 ?
http://www.repaircli...Number=WFMC3200
#3 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 08 April 2012 - 09:46 AM
Sounds like a classic bad pump too me.
make sure too remove to drain hose from the pump with care.
The drain hose has and external O-ring on it that can get cut or
roll out of place when reinserting into the new pump. a little lubrication
will help proper insertion.
www.eliteapplianceservice.org
