Asko Dishwasher D3251 DW20.3 Detergent door stuck closed
Asko Dishwasher D3251 Detergent door stuck closed
4 replies to this topic
#1 pigseye
pigseye
  • 3 posts
Posted 04 April 2012 - 12:28 PM
Hello All,
Have an Asko D3251 DW 20.3 Dishwasher. It's about 10 or 11 years old. The detergent door is stuck closed. Any trouble shooting suggestions?
#2 pigseye
pigseye
  • 3 posts
Posted 05 April 2012 - 11:00 AM
Any insight is greatly appreciated because I'm going to be digging into this problem this weekend.
  • 24,722 posts
Posted 05 April 2012 - 04:52 PM
So solly this one slipped by. Every Ass Co. d/w I've worked on with this problem it was either bad linkage or a bad heat motor inside the dispenser. Same deal with the Bosch's. Just replace the dispenser assembly, all good. ==> http://www.repaircli...tNumber=8073803
#4 pigseye
pigseye
  • 3 posts
Posted 15 April 2012 - 10:56 PM
Hello Samurai,
Appreciate the response. Unfortunately, the washer now has other problems. It's flooding and not draining. argh!
When I get a chance, I'm going to pull it out and run a cycle and watch it see where it's leaking. If you have any other suggestions that would be great.
Pigseye
  • 24,722 posts
Posted 18 April 2012 - 02:16 AM
Flooding and not draining is odd because if the flood switch gets activated, it runs the pump continuously. Drain pump is either bad or not getting voltage ==> http://www.repaircli...8078089/1488933
The parts manual is in the Downloads section ==> http://appliantology...r-parts-manual/
