  • Announcements
BlaneR
Washer jumping around like a fish out of water
19 posts in this topic
Kenmore front load Mdl 417.44072300. Replaced rear tub and back bearing about two years ago. Now it's making the same noise, but I'm suspecting the spider has broken this time (it was corroded and pitted real bad when I replaced the bearing). Suggestions on parts dealers? Did they ever finally decide to allow you to buy just the spindle and spider, or do you still have to get the whole basket assembly too?
I think the part number is 131618500
Thanks in advance!
Peace,
Blane
Kenmore 417.44072300. built by Frigidaire
if I were you,
I'd get a different Washer
If I were you, I'd listen to Sensei Reg
I agree!!!!
Most wash tubs for front loaders have a 15-25 year warranty. But I would scrap it and get a roper for $300. and call it a day. use youre front loader for a boat anchor
The tubs are rarely the problem. Usually bearing and drum spider.
the part may be under warranty but you have to pay for the servicer to come and do the job
Got it torn down, and it's the drum spider. If this is warrantied, how do I get a replacement part? This machine is eight years old. Like noted before, I replaced the back drum half due to a burned out bearing.
Thanks for the input. Sensei, seriously? All that mess is so danged expensive. If I was to get another front-load, what would you guys recommend?
Peace!
I think it's a ten year warranty on the spider but I'm not really sure. If you have your paperwork, call 'em up. If it aint under warranty then, my friend, you got to weigh the costs/benefits which means it's Kenny Time!
Edited by DurhamAppliance
to get the part warrantied you would have to call sears and have them come out and do the work...the part will be under warranty but you will have to pay the labor
I don't know if the Kenmore version of this Frigidaire built Washer has the same warranty as a "real" Frigidaire.
I've never even bothered to try this repair. When people call me I point out that the two metals between the drum and the spider are incompatible. Then I ask them "You got this 5 years ago, right?" Which they did. So the new one will last about the same time, as that is how long the metals have to react.. Plus you have to take the whole machine apart. From what I hear, it's a $700 repair, on an $800 machine, and the repair will only last you 5 years. Now granted you save the $300 on the part, but you are still throwing good money after bad. Put the $350 or so in labor towards something you won't have to put another $400 into in 5 years.
Kohai, just for posterity, it's called galvanic corrosion. It happens when you put two dissimilar metals together - they naturally generate an electrical charge, and the weaker of the two get eaten up. (Sorry, I'm an ex-Navy submariner - know all about that kinda stuff :thumbsup: ).
So, if I get this part, I will have put over $550 into a machine that cost $700 brand new. Should I roll on, or toss it? If I toss it, is there a machine out there worth having (front-load, that is)? I hate to use a top-load 'cause they use so much water and you can't do as big a load usually. Not that I'm a tree hugger or anything, I'm just trying to be a good steward and save me some money @ the same time...
Front loaders save water but swamp landfills. Choose your poison.
some are better than others...
We use an LG front loader.. has been working great for the last 4 years .. no problems ..
I suggest you try and find a standard directdrive top load whirlpool washer!!! There tough dependable and easy to fix and find parts for but there not making them anymore!!! But are still some left at local box stores (lowes,menards)! Cost less, clean better, just better period!!!!!!!
Derik,
. Although the Samurai seems to have soured on them, I still love my Staber washing machine. Like front loaders, it is a horizontal axis machine, though it loads though the top. It's a 50% price premium over what you have. It was designed by a repairman in Ohio who got sick of fixing junk. It's designed to be user servicable, and when my pump went out, it was right in front and easy to access!
Tim
Derik,
I still like them for all the reasons you listed! What I didn't like was their long production lead times and the uncertainties surrounding deliveries, endless problems with suppliers causing production delays, shipping snafus, and on and on.
Ours was good for six years 'til the bearing went out. I saw the condition of the spider then, and knew what was coming. Should'a just replaced it then.
Thanks for all the help/comments.
Peace!
