Whirlpool Duet Washer Error code F5 E2
#1
Posted 04 April 2012 - 07:40 PM
Model number is WFW9250WW00
I have checked the temperature sensor it read 15k at about 70 degrees.
Help but nothing is working.
-Pete
To estimate the time it takes to do a task:
estimate the time you think it should take, multiply by 2,
Then change the unit of measure to the next highest unit.
Thus we allocate 2 days for a one hour task.
#3
Posted 04 April 2012 - 08:26 PM
Ment to say thanks for the suggestion
#4
Posted 04 April 2012 - 08:30 PM
Check connections on door lock assembly
#5
Posted 04 April 2012 - 08:32 PM
#6
Posted 04 April 2012 - 08:34 PM
#7
Posted 04 April 2012 - 08:35 PM
#8
Posted 04 April 2012 - 08:36 PM
#9
Posted 04 April 2012 - 08:39 PM
Will repeat as sometimes this helps.
#10
Posted 04 April 2012 - 08:45 PM
#11
Posted 04 April 2012 - 09:01 PM
#12
Posted 04 April 2012 - 09:07 PM
#13
Posted 04 April 2012 - 09:22 PM
#14
Posted 04 April 2012 - 09:30 PM
#15
Posted 05 April 2012 - 07:22 AM
#16
Posted 05 April 2012 - 10:00 AM
issue wasn't there before Baffle replacement ?... issue started after new baffle. .
Was the Washer Power Cord un-plugged before work was performed ?
#17
Posted 05 April 2012 - 08:07 PM
#18
Posted 05 April 2012 - 08:24 PM
#19
Posted 05 April 2012 - 09:25 PM
? ? ?It had cropped up months before baffle replacement but not before the replacement/
#20
Posted 05 April 2012 - 09:35 PM
Now machine was placed into final location and replaced the baffle. Then got error code. Did check before put the baffle in and did not have code right before replacement was installed.
Sorry fo rthe confusion on this.
I did unplug the unit before disassembly.
thanks
Also tagged with one or more of these keywords: Whirlpool Duet Washer
Appliantology Appliance Repair Forums →
The Laundry Appliance Repair Forum →
2004 Whirlpool Duet Washer model # GHW9100LW1 making knocking noise on spin cycleStarted by LifeofLaundry, 12 Feb 2012 |
