Frigidaire double wall oven PLEB30T8CCA both bake elements not working
#1
Posted 04 April 2012 - 10:57 PM
#2
Posted 05 April 2012 - 12:02 AM
As Well some relays can be opened/taken apart and you can use a points file and contact cleaner to clean them but youre taking contact surface away and the can get stuck again. I practiced on boards in the shop before I began trying it in customers home.
- Samurai Appliance Repair Man likes this
#3
Posted 05 April 2012 - 03:00 AM
.... you can feel a little warm from the broil element during baking preheat but cold bake elements.
if only the broil Element is (somewhat) working, then it wouldn't be a bad DLB Relay nor the Thermal Circuit Breaker.
It would be the Relays on the corresponding Relay Board
Upper Oven relay Board
http://www.repaircli...?R=154&N=499739
Lower Oven relay Board
http://www.repaircli...?R=154&N=499738
- Samurai Appliance Repair Man and kdog like this
#4
Posted 05 April 2012 - 05:53 AM
If you find broken/burnt/cold solder joints at the relays clean and re-solder and it should be good to go.
- RegUS_PatOff likes this
Eureka, CA 95501
