Kenmore dryer 110.66912692 shuts off
66912
11 replies to this topic
#1 emitch143
emitch143
  • 5 posts
Posted 06 April 2012 - 08:50 AM
Kenmore dryer (110.66912692) shuts off after 10 minutes. After running for 8 minutes, the dryer starts to make an unusual noise and gets louder until it shuts off. I can restart the dryer after about 20 minutes with same results. I read through some FAQs and accomplished a few checks. I would appreciate if someone would validate my diagnosis or tell me what to check next. First I checked the exhaust vent/vent hood/and airflow from the back. . .no obstructions. No obstructions either in the lint duct assembly. The drum seems to not be restricted from movement or misaligned. After the dryer stopped, I touched the motor and had to pull away after 3 seconds due to heat. I believe the motor is bad. Thanks.
#2 RegUS_PatOff
  • 30,273 posts
Posted 06 April 2012 - 09:26 AM
... shuts off after 10 minutes. After running for 8 minutes,
... starts to make an unusual noise and gets louder until it shuts off.
... I can restart the dryer after about 20 minutes
... After the dryer stopped, I touched the motor and had to pull away after 3 seconds due to heat.
... I believe the motor is bad.
yes ... common problem
remove the Belt and try tuning the Motor Shaft by hand
Does it turn easily, smoothly ?
http://www.repaircli...asp?R=154&N=158
#3 emitch143
emitch143
  • 5 posts
Posted 06 April 2012 - 12:16 PM
I removed the belt and the shaft turns relatively easy. I ran the dryer (no clothes) and it shut down after about 13 minutes this time (noise occurred 30 seconds before it shut down). Motor was still too hot to touch more than 3 seconds and the shaft moved as easy as before I ran the dryer. Thanks.
#4 RegUS_PatOff
  • 30,273 posts
Posted 06 April 2012 - 12:51 PM
and smoothly ?
should be able to "spin" the Shaft and it will continue to turn somewhat ...
  • 24,333 posts
Posted 06 April 2012 - 08:06 PM
Replace the motor ==> http://www.repaircli...otor/279787/158
#6 kdog
    RoughShod
  • 7,428 posts
Posted 06 April 2012 - 08:08 PM
Other parts of interest here
#7 emitch143
emitch143
  • 5 posts
Posted 07 April 2012 - 07:41 AM
Shaft rotates smoothly. Continues about 1 full rotation after I let go.
  • 24,333 posts
Posted 07 April 2012 - 09:33 AM
With the belt strung on the motor and drum, open the door and turn the drum by hand. Does it about break your arm trying to turn it? If so, there's a drum roller problem. If not, replace the motor.
#9 RegUS_PatOff
  • 30,273 posts
Posted 07 April 2012 - 09:35 AM
you could try running the Dryer in an Air-Fluff (no-heat) cycle with the Belt removed,
but you'll have to hold the Belt Switch (somehow)
to see how long it runs and if the Motor still gets hot.
#10 emitch143
emitch143
  • 5 posts
Posted 12 April 2012 - 07:02 PM
Sorry for the delay. Turning the drum by hand was relatively easy. Dryer run in Air-Fluff cycle with belt removed resulted in dryer stopping after only approx 15 minutes. Motor was not too hot.
Mistake. . .dryer shut off after 1.5 minutes and not 15. . .
  • 24,333 posts
Posted 12 April 2012 - 09:31 PM
Replace the motor; click the pick GMF Reg posted for you.
#12 emitch143
emitch143
  • 5 posts
Posted 13 April 2012 - 07:37 AM
Many thanks.
