#1
Posted 07 April 2012 - 01:18 PM
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
I checked the door latch which seemed to be fine. Please see the video for more information.
http://www.youtube.c...h?v=mqCbzXUuGyg
Appreciate your assistance. I didn't want to replace the entire board if the fix is simple.
#2
Posted 07 April 2012 - 04:48 PM
Try pushing the Door closed while trying again.... I checked the door latch which seemed to be fine.
Have you electrically tested the Door Switch ?
#3
Posted 07 April 2012 - 05:27 PM
Appreciate your response.
I tried that. How do I electrically test Door Switch?
#4
Posted 07 April 2012 - 05:48 PM
may need to remove the Door Panel to access the Switches.
The stainless steel Tubs use one Door Switch,
the plastic Tubs use (2) Door Switches (# 12)
The affected Switch will Have a Tan Wire and a B/W wire
#5
Posted 07 April 2012 - 08:16 PM
See for the test
#6
Posted 07 April 2012 - 09:43 PM
(nice video)... I took apart the door panel and tested the switch. both read to 0
Switches seem good, although usually tested while still installed,
and Door in "closed" position so as to simulate an actual closed Door / Latch.
The Door Latch assembly that holds the Switches, may be damaged / skewed
OR the Door Strike / Actuator may have become bent / dislodged from the Cabinet / Counter Top
