Whirlpool RBD306PDQ7 Electric Double Oven lower door locked
22 replies to this topic
#21 rican
rican
  • 16 posts
Posted 10 April 2012 - 02:46 PM
OK, stuck a screw driver in the latch and pushed the solenoid pin back the blocked the latch. It stayed back and the latch works fully and does not latch the door. I turned the power back on to the unit and the top oven works now. The lower does not heat up. I did find that the lower oven thermostat was test OL on the multimeter could this be the cause?
I know that I have not tested the controller board yet, but does this inidicate that the solenoid might be bad as it did not open in the lock postition when the power was restored?
#22 RegUS_PatOff
  • 30,701 posts
Posted 11 April 2012 - 11:29 AM
... The lower does not heat up. I did find that the lower oven thermostat was test OL on the multimeter could this be the cause?
yes
#23 Samurai Appliance Repair Man
  • 24,720 posts
Posted 12 April 2012 - 03:33 AM
Sounds like you done found the problem! ==> http://www.repaircli...r-Breaker-Parts
