Sign in to follow this
Followers 0
cjdwight
PSW23PSWASS GE Side by Side - access to mainboard
5 posts in this topic
I have a GE side by side PSW23PSWASS with the dreaded temperature irregularities and thawing ice in the ice tray. We've had some pretty good power surges this year, and I'm thinking the motherboard is fried. Once repaired, I'll be sure to place a good surge suppressor between the outlet and the fridge. For now, the fun upside is the spectacular icicle that grows inside my freezer.
Looking at the back of the fridge, the motherboard access panel is obvious. The challenge I foresee is that the screws on the right side of the panel (when looking at the back of the fridge) are covered by the freezer-side side cladding. I have removed the top trim and yet cannot find any way to remove or move the side cladding to gain access to the motherboard panel. Any suggestions?
Will definitely check the thermistors - not sure which would be easiest to access. I'll study the drawings a bit and figure out where to start. Meanwhile I can make a nice cocktail for my wife using my giant icicle as both a drink chiller and cocktail stir stick. Still curious how to remove the side cladding - why they designed the thing to cover up the motherboard panel is beyond me.
Some of these have a small phillips screw holding that panel. Remove it and pull the panel aside enough to remove access cover.
There are two phillips head screws, one near the top and one near the bottom of the side panel on the back of the fridge - I removed both of these (after removing the top trim panel), but the side panel wouldn't budge. I looked all around and could not see any other fasteners. I felt along the bottom of the trim panel, and could not feel any fasteners on the bottom. I'm a bit perplexed on how the panel is attached. The cladding parts diagram doesn't show anything helpful.
Followers 0
