GE sxs PSC23MGNACC no water at dispenser
#1
Posted 10 April 2012 - 01:56 PM
Tried to heat tube at dispenser, no go.
Tried to fish wire from both ends of tube, still no go.
Question:
Will wr49x10173 heater kit work for this model?
Also, if anyone has installed one of these, where do the wires connect?
Can you coach me through the disassmbly of the dispenser without destroying it?
Thanks for any help.
#2
Posted 10 April 2012 - 07:50 PM
But I'm sure that kit will work on your model. According to that bulletin, it applies to model BSS, DSS, ESH, GSH, GSS, GST, HSS, SSS
- DurhamAppliance and tpoindexter like this
#3
Posted 11 April 2012 - 02:38 AM
Disconnected tube at lower freezer door, water shoots out at connector.
Question:
Instructions as provide by the Great One make the installation quite easy. With regards to removing the ice from the tube....once again I have had luck with none other than my handy dandy steamer. I've had good results with shooting steam from the tubing at the bottom and through the spout. But the kit is necessary for prevention.
#4
Posted 11 April 2012 - 11:58 PM
Here is an update:
Customer called this pm and said the dispenser is now working. What the ....
Part already ordered, probably should be installed anyway.
Any tips on taking the disp apart?
#5
Posted 14 April 2012 - 10:52 AM
Yes, you still need to do the repair since the problem will reoccur.
get a small screwdriver or pointy object and press in the tabs from below the touch pad. Instructions come with the kit and quite easy
You get some splicing thingamadoodles with the kit..(red things in the following picture) per instructions ..simple, just clamp the watchimacallits on designated wires and ta da!. .Bob's your uncle! Then strut around the kitchen shouting "yoo hoo! "Who's yo daddy?" "How ya like me now", 'I be da man!" .."dont taze me bro!" or simply say them to yourself while asking for the check.
http://www.repaircli...R=154&N=1381601
Edited by Mrs. Samurai, 12 May 2013 - 08:02 PM.
- Samurai Appliance Repair Man and tpoindexter like this
#6
Posted 14 April 2012 - 04:16 PM
Thank you for your expertise. I'll put that to use as soon as part arrives and to be sure i will do a dance and shout "Don't taze me bro" or somthing like that.
- DurhamAppliance likes this
How to install the heater kit on the dispenser of a GE refrigerator to stop it from freezing water in the tube
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 14 April 2012 - 06:28 PMWrong.
Yes, you still need to install the heater kit. Don't believe me? Yeah, I know, I'm just a semi-lucid, mostly-fermented Samurai so, heck, I don't blame you-- half the time, I don't believe me, either! But perhaps you'll...
Read Full Entry →
