How do you remove a rusted pump on a direct drive washer? 110.26722690
9 replies to this topic
#1 trevorstorey
trevorstorey
    Ikkō-ikki
  • 25 posts
  • Flavorite Brew:Homebrewed IPA
Posted 10 April 2012 - 03:01 PM
I've got a Kenmore washer MOD: 110.26722690, that has a driveshaft which has been joined by the bonds of RUSTY matrimony to the pump. I did some pretty nasty things to the two of them to try to induce a divorce but to no avail.
First I pulled with my Olympic arm wrestling hands, then pried with a screw driver, then I pried with a cats paw, then a hammer and crow bar. NOTHING!
Then I decided its power tool time! Got out the grinder and cut away the pump. Finally I was able to rip off all the existing pump and rust.
BUT.....In the process it looks like I damaged the front of the motor (see in attached photo #1).
My Questions are:
1) Can I still use this motor? Picture #1 (3363736) It looks sketchy....
2) Is my other motor (8528157) compatible? They look like the same exact motor?
3) Are there any more efficient ways of removing a rusty pump from the driveshaft other than brute force?
4) Is there anything you can put on the driveshaft/pump interface to avoid rust build up?
#2 kdog
    RoughShod
  • 7,428 posts
Posted 10 April 2012 - 04:05 PM
1) No, that Motor looks pretty much hatched
2) Yes, those 2 part numbers sub to the same
3) Thats what I have had to do on numerous occasions, if it looks like it ain't gonna come - chisel the centre from the pump and use a rotary tool to grind/split/clean the pump material from shaft. Note that as water leaks from the centre of pump that it also contaminates the front bearing in the Motor.
4) A wee dab of anti-sieze lube, or axle grease to the shaft when pump is installed certainly can't hurt. The best defense is occasional removal and inspection so it may be solved prior to escalating to this level.
Part Links:
http://www.repaircli...er=110.26722690
#3 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 10 April 2012 - 09:05 PM
I use a 1" hole saw right down the middle of the pump then clean the motor shaft up with 3" makita disc grinder. Takes about ten minutes.
#4 john63
john63
  • 1,411 posts
Posted 11 April 2012 - 12:10 AM
<<<I use a 1" hole saw right down the middle of the pump>>>
This is what I love about this forum---learning others tech's solutions that are so simple and practical---that it makes me grin & chuckle :)
Great tip!
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#5 trevorstorey
trevorstorey
    Ikkō-ikki
  • 25 posts
Posted 11 April 2012 - 12:33 PM
Thanks Dudes, this info has been mondo helpful!
#6 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
  • Flavorite Brew:yeunling
Posted 11 April 2012 - 04:56 PM
yep learned about the hole saw idea from the old guy that trained me to fix washers and dryers
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 11 April 2012 - 07:48 PM
Right effin on! I love a reason to get out the grinder....
"If you insist on watching over my shoulder ma'am, I must insist you put on these safety glasses..."
Edited by KurtiusInterupptus, 11 April 2012 - 07:48 PM.
#8 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 15 April 2012 - 09:41 AM
normally i can get them off with a hammer...but every now and then.....
www.eliteapplianceservice.org
#9 kdog
    RoughShod
  • 7,428 posts
Posted 27 April 2012 - 09:28 PM
The Pump, or the Customer on your shoulder ?
#10 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 28 April 2012 - 06:53 AM
;) its Hammah time!
