Sign in to follow this
Followers 0
Maddie Pana
(ancient) Maytag DE407 clothes dryer, changed drive belt, no joy
9 posts in this topic
I have a truly ancient Maytag DE407 clothes dryer (think avocado green!). A few months ago, the drum quit turning so I flipped the drive belt to get the drum turning again as it was the holidays and I was too busy to chase down a new belt.
Naturally, I got distracted with more immediate things and never got around to ordering the part (so old that local parts houses do not carry it!)
Last week, the drum quit turning again, so I placed an order for a new drive belt (Whirlpool y311012) which I picked up yesterday and installed today. I've checked and rechecked the belt lie and it is too loose to turn the drum despite appearing to be installed correctly. I checked the part number on the belt that I removed (on the off chance that some previous repair necessitated the use of a different belt, but the part number is the same as the belt that I just installed.
I did not replace the motor belt (Whirlpool y311013) because it is in good condition and it has a nice, snug fit. The spring also appears to be nice and tight.
Is there any way to adjust the tension (or any other obvious mistake that a not terribly mechanically-inclined woman might make)? I don't expect it to run forever, I'm just looking for a way to make it work for a month or so while I take my time shopping for a new washer/dryer set so that I can get a decent price on what I really want instead of whatever I can find right now. (You know, what I *should* have been doing when I flipped the belt lol)
Wow---that is an old model :)
Disregard the previous post.
This dryer uses dual "V-Belts".
Possible seizing bearing in either the BLOWER ASSY or DRUM BEARING.
Also possible failing MOTOR (under load).
It's been at least 20 years since I've seen one of these old Maytags.
for reference
Pull inside belt off of motor to make it loose. Open door and try to turn drum by hand. If it turns blower is seized on drum shaft. If it still does not turn then drum shaft is seized in its bearings (most likely). Either way this is a big project.....had to put on a pretty old hat for this one. A great dryer in its day. Good luck!
I was fairly confident that I didn't have bearing issues or anything seizing as the old beast hadn't been making any strange noises. I don't know what I did differently, but I took everything apart again, went to make dinner, and came back afterwards to put it back together and everything was fine. Something obvious, I'm sure, but just the same ... hooray for clean *and* dry laundry! (Can't hang things out due to smoke from the wildfires here in FL just now)
I'll actually be sad to see the old beast go ... I think I'd be scared to work on anything with an actual computer in the control panel lol (I miss carburetors, too. I may not be able to rebuild one but at least I understand what they do. I recently had to help a friend jumpstart her Prius and it took a quick scan of the manual ... they hide the positive terminal for the 12 volt under the fuse box cover. That's just mean!)
Now to actually do the research on new washers and dryers so that I know what I want to buy and can watch for a good sale :)
Thanks for the advice, guys!
Maddie the near-Luddite ;)
Whats wrong with this picture? Where are the energy saving (not money saving) computer boards and sensors?
Geesh, how many different brands of laundry detergent do we need? Also, what is dishwasher detergent doing with the laundry detergents in the above picture?
Followers 0
