GE Inverter Board Washer WWSE5240G3WW Slow Spin
2 replies to this topic
#1 Rodgers Appl.
Rodgers Appl.
    Yamabushi
  • Chief Appliantologist
  • 66 posts
  • Flavorite Brew:Bud Light Lime
Posted 16 April 2012 - 08:36 AM
I am working on a GE inverter type top load washer that will go through the entire wash cycle fine , but when it gets to the spin section it drains, spins slowly for time, then spins fast for about 30 sec. then will slow down and spin slowly for about 5 min. I have put the machine into the field service mode and selected the spin cycle and it only spins at the slow speed (about 50 RPM). The LED flashes normally (1 sec on/off when idle and .5 sec on/off when running). Any insights?
    Shōgun
  • Master Samurai Tech
  • 30,943 posts
Posted 16 April 2012 - 04:25 PM
Are you getting 9vdc at all indicated points on the C4 connector in test mode (see the illustration below)?
#3 Rodgers Appl.
Rodgers Appl.
    Yamabushi
  • 66 posts
Posted 17 April 2012 - 04:29 PM
I just tried the test and I am getting 9 VDC at all of the C4 pins. But the thing still will only spin at a slow speed in the test cycle after i plugged it back in. This frickin' thing is enough to drive a guy mental!
