Kenmore Model # 417.44092500 No Spin
Kenmore Front loader HE No Sp
3 replies to this topic
#1 AvanteAppliance
AvanteAppliance
    Ikkō-ikki
  • 47 posts
  • Flavorite Brew:Miller Lite
Posted 18 April 2012 - 11:41 AM
Hello,
I am working on a Kenmore Model # 417.44092500, when i select the drain/spin option on the dial and hit start, the pump is actuated and starts to pump and the timer runs down, then it starts to tumble, first to the left and then to the right. It does this for about a minute or more, then it shuts off, timer display goes black and then starts to beep very angrily with no tub action whatsoever. I already switched out the motor control board being that was what I thought was wrong, turns out the diagnoses is wrong. I am guessing its either the main control board or the door lock mechanism. Any suggestions? Thank you.
"Get crunk with it get loose with it, my clients don't care as long as your @$$ fixes it."
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 4,721 posts
Posted 18 April 2012 - 12:03 PM
Door switch, soap dispenser and board are good suspects but first check to make sure the pump and the drainage tube are free of debris
Edited by DurhamAppliance, 18 April 2012 - 12:04 PM.
www.DurhamApplianceThrift.com
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 April 2012 - 10:57 PM
Kenmore Model # 417.44092500 made by Frigidaire
While it's in the Spin Cycle, is the Door locked ?
Is it really locked ?
If so, un-plug the Power Cord from the Wall Outlet.
Can you open the Door right away ? > bad Door lock Assembly
OR only after a few minutes ? > good Door Lock
http://www.repaircli...R=154&N=1531974
#4 Derik
Derik
    Sōhei
  • Master Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 21 April 2012 - 12:45 AM
changed two of these door locks this week?and probally 30-40 in the last 4yrs, common problem
