Frigidaire Gallery Dryer, Sparks
Sparks dryer
6 replies to this topic
#1 evick85
evick85
  • 2 posts
Posted 21 April 2012 - 02:48 AM
I was drying cloths just like normal and right by the base of the plug it started sparking and shut off. Ive read alot of forums with improper wiring, but I dont know if this is the case.
#2 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 21 April 2012 - 05:34 AM
It will be the case.
Time for a new dryer cord.
Also,turn off breaker to dryer,remove the outlet cover and inspect the outlet terminals.
It most likely needs replacing too.
The terminals will be loose and scorched.
#3 RegUS_PatOff
  • 30,689 posts
Posted 21 April 2012 - 06:51 AM
has this Dryer worked OK for you up till now at this locaton ?
Dryer may also have a Heating Element that is shorted to chassis (ground)
#4 evick85
evick85
  • 2 posts
Posted 21 April 2012 - 04:22 PM
The dryer has been FLAWLESS... Now if it is the case with a new cord, Im assuming the terminal that holds the wires needs replacing as well?
#5 jumptrout
jumptrout
  • 1,192 posts
Posted 21 April 2012 - 05:01 PM
Maybe.maybe not. I am referring to the terminals inside the wall outlet. The wall outlet may need changing.
#6 RegUS_PatOff
  • 30,689 posts
Posted 21 April 2012 - 06:51 PM
http://www.repaircli...?R=154&N=936847
OR
http://www.repaircli...?R=154&N=916788
#7 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 22 April 2012 - 08:14 AM
whirlpool has a kit with 3 terminals with a foot of wire and wire nuts, thats what i use regardless of brand to fix this problem
Also tagged with one or more of these keywords: Sparks, dryer
