KENMORE ELECTRIC DRYER MODEL 11068944892
7 replies to this topic
#1 desertfox40
desertfox40
    Yamabushi
  • Chief Appliantologist
  • 76 posts
Posted 21 April 2012 - 12:07 PM
Dryer was not working. Replaced high-limit thermostat; dried a load of laundry and it worked fine. Tried another load, but drier does not work anymore. Thermostats are all fine. I am wondering if control module went out and is there a way of checking it?
#2 vee8power
vee8power
    Kohai
  • 487 posts
  • Flavorite Brew:Folgers
Posted 21 April 2012 - 01:54 PM
Dryer was not working at all before you replaced hi limit, or just not heating? And now no running or no heating?
    Shōgun
  • Master Samurai Tech
  • 30,727 posts
Posted 21 April 2012 - 02:13 PM
And you RE-checked the hi limit thermostat?
#4 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 21 April 2012 - 05:10 PM
Please start at the beginning and tell us what happened and what does not work.
#5 desertfox40
desertfox40
    Yamabushi
  • 76 posts
Posted 23 April 2012 - 08:43 AM
Sorry for the delay. The dryer was working and then it stopped putting out heat. Checked heating element and it was fine. Checked the thermostats and found hi-limit thermostat was open. Replaced the hi-limit thermostat and that fixed the problem. Dried a load of clothing and it worked fine. Tried another load and now it won't start at all. Checked all thermostats and heating element and everything checks ok. Drier is dead. Kaput. I have not yet taken any voltage measurements as I don't have schematic.
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 23 April 2012 - 12:51 PM
110.68944892
I can't find a wiring diagram for that model, but I found one for
110.68944890
Have you checked:
re-set the House Circuit Breakers
Thermal Fuse
Thermal Cut-off
High-Limit Thermostat
Belt Switch
maybe similar
Tech Sheet - 3406532.pdf
link PM'd
#7 jumptrout
jumptrout
  • 1,382 posts
Posted 23 April 2012 - 01:33 PM
Yes,check for 220 volts to the terminal bar on the dryer.
Check the door switch for continuity.
Check the thermal fuse on the blower housing for continuity.
#8 desertfox40
desertfox40
    Yamabushi
  • 76 posts
Posted 24 April 2012 - 07:05 PM
Thanks to all. I got the schematic and will check all items listed. Will report my findings later as I am working on other items.
