mah6700aww gets upside down F and E error code
3 replies to this topic
#1 kona-boy
kona-boy
  • 1 posts
Posted 21 April 2012 - 02:24 PM
I have a maytag washer mah6700aww that give an error code after it warms up. If I do a quick wash it may make it all the way through. but next load gives a FE code with the F upside down. Ran Diag and all tests pass. Normal cycle will usually run about half way befor error.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 21 April 2012 - 07:23 PM
... upside down F and E error code
lower case t E ?
Sump thermistor failure
Thermistor
Unplug harness connector and test from wire insertion side of connector.
Pin #6 and Pin #3 of CN3
13K ohms @ 70F (2.5V DC)
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 5,635 posts
Posted 21 April 2012 - 07:25 PM
I am guessing that is an "LE" error code. From my research, two possibilities....water level error (check your drain hose) as found in the owner's manual or overheating motor as found in the service manual.
lower case t E ?
makes more sense
www.DurhamApplianceThrift.com
#4 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 21 April 2012 - 09:55 PM
Yes---as RegUS mentioned---the "tE" error is a Thermistor Error.
Can be caused by:
1) Corroded plug connection at THERMISTOR (common)
2) Failed HEATER (can be tested for continuity with a test meter)
NOTE: The THERMISTOR can be access from the bottom of the washer---if an assistant can tip the washer back.
The location of the *bullet-shaped* sensor is at/near the 6 o'clock position on the front of the tub.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
Maytag Neptune washer with a tE error code
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 22 April 2012 - 03:54 PM
Model number mah6700aww
[quote name='john63'...
Read Full Entry →
