Sparkland
Kenmore Elite icemaker will not work
17 posts in this topic
I have a kenmore elite refrigerator #10652693100, recently the ice maker will do nothing. The optical sensor is not flashing (no light whatsoever) and the ice that is in the icemaker is just sitting there.
Does not seem to be anything happening. We checked the water in the door and that is working fine, so I assume the water line is okay. The ice crusher and dispensor do work.
We previously had the optical sensor blink when an icecube was stuck or something, but not this time. Acts like it has no power.
Is it just better to get a new unit? This one is 4 years old. I would rather not call the repair man since I can buy a new one for the price of a service call.
Thanks, Brad
[user=517]Sparkland[/user] wrote:
The LED is not flashing (no light whatsoever)
Are you referring to the LED on the dispenser control panel?  I don't think your fridge has the optical ice control system.
We preciously had the LED blink ...
I love those precious little LEDs, too!  :goofus:
You can remove the cover off the icemkaer module head and jumper out test points T to H to initiate the ice harvest cycle
I am having trouble getting the icemaker out of the refrigerator. Am I supposed to just be able to push up the little clips and it will release. I can get the left one loose but not the right one as I face the icemaker in the refrigerator.
Brad
You don't have to remove the icemaker to test it! Just pull off that white plastic cover on the front of it.
Sorry for the confusion, but my icemaker sits from right to left with the motor on the left side. I do not see how I can access this part without removing the icemaker. Am I that dense?
Well in that case you do have to pull out the icemaker, it is a pain in the:moondance:butt it is possible with a little twisting and turning, same test points as Samurai mentioned, have a cup ready to catch the water.:stooges:
I found the problem. Took the hair dryer out and "styled" the icemaker. Apparently it was frozen in place. Now it works like a champ. Thank you for your help. Brad
Uh huh, frozen water fill tube.  :bart:
No ice again,
Guess I was just lucky to get the temporary fix. The icemaker will not operate at all.
The Kenmore Elite 10652693100 has the Whirlpool icemaker, but the problem is: I went to the Sears parts store and they said I could not order the whole unit, because there was no part number for the entire unit. Can this be true?
Any help would be appreciated. I looked on a couple of parts outlets on the "net" and could not find the whole unit either.
Brad
Well, a replacement I/M is available at:
http://www.repairclinic.com/0081.asp?RccPartID=1857
Go there via the box at the bottom of the page. HOWEVER.......
I don't think thats your problem. These are notorious for freezing the fill tube, so much so that Whirlpool brought out a revised tube with a small heater incorporated. What's your serial number (should be S, another letter then 7 digits)?
Here is my serial number SL (might be a 1) 3739254
Thanks for the help. Brad
Could I order this heated tube part separately?
Another side note. My wife loves to "pack" the freezer section of this side-by-side so that the air flow is, to say the least, restricted. Could that be a contributing factor to my problem?
Finally a good reason for my wife to leave a little room in the freezer so the kids and I can have some room for ice cream. No other reason ever seemed to work. If she wants ice then she will have to cut down on the "stuffing"
Crazy thing is we have two side-by-sides (one in the garage) and one freezer downstairs, so it is not like she has no storage space.
Brad
Yours is the right age to have this problem. The heated tube is Whirlpool part number 4389174, follow the instructions EXACTLY!
Here's the filltube heater kit you need:
Thanks for all your help. I am waiting for my wife to unload the freezer and defrost the line before I tackle the job of putting in the heater element, but I will.
I will let you know how it goes. Great help on this forum.
Brad
Just to keep you updated, I am still waiting to get the freezer thawed out. The groceries have nowhere to go.
My wife just keeps stocking up.
Thanks, Brad
She will have no ice until she stops going to the store.  ;)
