Samsung Refrigerator RFG297HDWP/XAA Icemaker not working
Samsung refrigerator ice maker RFG297HDWP/XAA
4 replies to this topic
#1 Samurai Appliance Repair Man
  • 24,243 posts
Posted 22 April 2012 - 05:30 PM
Howdy guys, it's my turn to ax a question!
Got a customer with a Samsung RFG297HDWP/XAA refrigerator and the ice maker isn't working.
I've not been out on this one yet so haven't checked the usual things: freezer temperature and water inlet valve.
Also, how to run the ice maker thru a manual harvest cycle?
Domo for any help!
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 22 April 2012 - 06:21 PM
from scouring the internet ice maker part DA97-07365A has a test\reset button on it that will initiate harvest. Other samsung ice makers have a button on the bottom that initiates harvest but different part no for the ice maker. With your particular Ice maker there is also a button based on the following from a thread :that although references a GE Fridge, it uses the same ice maker as the model you will be repairing
I have A GE Profile frige (PFSS9PKYASS) with a Samsung ice maker (DA97-07365A).
After replacing the water filter, the ice maker made very very large cubes and the pressure from the in-door water dispenser increased. Now the ice maker will not work (cycle) automatically.
It will work only when I push the reset button. The maker will cycle, dropping the ice and then refill. when the maker refills a "ding-dong" tone sounds (error code?). Then, as stated above, the ice maker will not drop ice unless I push the reset button. I have removed the ice maker from the refrigerator for several hours (hoping to reset it) but upon reinstalling it, the same continues. I have also shut off power for 10-15 min. but it's just like pushing the reset button. I
Edited by DurhamAppliance, 22 April 2012 - 06:36 PM.
#3 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 22 April 2012 - 06:46 PM
This ice maker fails frequently...I stock it.
I dont have a schematic but power in and no cycle....IM bad
www.eliteapplianceservice.org
  • 24,243 posts
Posted 22 April 2012 - 07:00 PM
Awesome info, Durham and appltech! :thumbsup: :dazzler: Mucho domos, dudes!
Going out on this one Tuesday, will post findings.
  • 24,243 posts
Posted 06 May 2013 - 10:07 PM
Dang, forgot to post followup!  Turned out the icemaker was jammed-- the cubby was jammed with ice preventing the icemaker from cycling.  Cleared the jam and rocked on!    :rocker:
Also tagged with one or more of these keywords: Samsung, refrigerator, ice maker, RFG297HDWP/XAA
