Whirlpool Fridge (GS6SHAXMBO0) compressor running but everything room temp
compressor humming no cooling
10 replies to this topic
#1 nowarranty
nowarranty
  • 9 posts
Posted 24 April 2012 - 09:33 PM
Hello,
I have a situation with a 7 year old Whirlpool conquest where it is no longer cooling. All components are on (lights, cond fan, evap fan). However, the compressor is constantly humming and not changing temperature. I thought it was the start device so I replaced that - no change. Also, the condenser coils have been cleaned.
Am I looking at a bad compressor? Or is there something else I should be looking at? I find it interesting that I hear no clicking, just a constant hum from the compressor.
Finally, we also had a surge protector in the house go bad and a computer hard drive go bad around the same time, not sure if this is coincidence or a electrical surge root cause.
thanks.
#2 RegUS_PatOff
  • 30,198 posts
Posted 24 April 2012 - 09:40 PM
Has this Fridge been working OK for you up till now at this location ?
Would need to a picture of the frost pattern (if any) of the Evaporator Coils inside the Freezer
#3 nowarranty
nowarranty
  • 9 posts
Posted 25 April 2012 - 05:12 AM
The fridge stopped working over a week ago (the contents were transferred to another fridge/freezer). It has been unplugged for at least 5-6 days. So I assume that would mean there would be no frost patterns? Or should I let it run again and then look for a pattern?
After replacing the Start Device last night I let the unit run for 15mins and all components were room temp. Even the compressor. It had the loud hum, but no change in temp. So if I do look for the frost pattern, how long should i let it run for prior to taking a picture?
thanks again.
#4 RegUS_PatOff
  • 30,198 posts
Posted 25 April 2012 - 05:41 AM
about an hour or two
#5 nowarranty
nowarranty
  • 9 posts
Posted 26 April 2012 - 09:33 PM
It ran for a few hours and the evap coil shows no signs of frost.
The coils is clean and room temp.
Compressor had the same consistent hum the whole time. Trying to figure out how to post a pict... but not sure if will show you much other then a clean frost free coil.
thanks
#6 jumptrout
jumptrout
  • 1,126 posts
  • Flavorite Brew:Coors Light
Posted 27 April 2012 - 09:18 AM
Place your clamp on amp meter over 1 compressor wire to get an amp draw reading.
Should read about 1,2 to 1.6 amps.
Sounds to me like a refrigerant leak.
#7 nowarranty
nowarranty
  • 9 posts
Posted 27 April 2012 - 11:12 AM
I'll check amps. But assuming I register appropriate amps, I suspect it will still be a few hundred $$'s to have a technician find, repair and recharge. With a replacment value on teh fridge at $900 sounds like it might be time for a new one.
Feel free to let me know if think my thinking is flawed.
Thanks again.
#8 DurhamAppliance
    Sho' Nuff Chozin
  • 1,716 posts
Posted 27 April 2012 - 06:05 PM
is that hum the normal compressor sound? is the compressor both warm and vibrating? also you may want to check the run capacitor if all other tests show no problem.
#9 nowarranty
nowarranty
  • 9 posts
Posted 27 April 2012 - 06:17 PM
it's definitely not a normal sound it's a steady, almost vibrating hum, you can easily notice it just walking into the room. it is vibrating slightly, but its a steady vibration. it's not getting warm at all...
#10 jumptrout
jumptrout
  • 1,126 posts
Posted 27 April 2012 - 07:26 PM
And the amp draw is.......................???
#11 nowarranty
nowarranty
  • 9 posts
Posted 29 April 2012 - 09:27 AM
it was hovering up around 1.6....
Also tagged with one or more of these keywords: compressor, humming, no cooling
