GeneP
LG WM2701HV Main Control Broard
5 posts in this topic
I have a LG WM2701HV front loading maching that is just less than 1-1/2 years old. Last week while washing a medium load of sheets I found the Laundry Room (8x13 room) full of horrible smelling smoke (A week later I am still trying to get ris of the smell). Anyhow I removed the top to find the main control board literally fried between the 2 relays. It actually burnt a hole through the circuit board, the potting material that secures the board to the back cover, with residue running down the back inside of the washer. Nasty smelling stuff! I called LG & explained what happened hoping to get a new main control board that should be covered (2 year board warranty on the board). They gave me a CNM# and said they would contact me in a few days. After a couple days I called again asking what happened with no real resolution. I have not been able to find a Service Manual or Schematic on line. Anyhow my question is: If I replace this main control board can I expect it to again fry as I suspect the problem to be something else defective causing the main board to fry? The burn components appear to be some sort of "Switching Relay" maybe what makes the drum rotate back & forth in different directions. I see no other burnt wires or components visually but gut feeling might be a stator??? I could check resistance across the stator if I know what it should be. a couple photos I will try to attach might help.
Any and all comments or recommendations would be greatly appreciated.
Gene
post-70317-0-15113500-1335364078_thumb.j
post-70317-0-74643800-1335364082_thumb.j
An unusual MAIN BOARD failure.
It appears that the power-input relay failed (dramatically).
No other components on the washer caused this to occur.
http://www.repaircli...Number=WM2701HV
Edited by john63
Thanks for your quick reply John63. So my understanding is that this type a failure IS "Unusual" and you wouldn't expect another bad component elsewhere. My last contact with LG (Not a good conversation) was that they wanted me to pay for their service & labor to replace the board while I would expect their labor charges several times more than your quoted board cost (Or their cost). Before I pay them I plan to purchase the board myself and do the install. Hoping I don't fry the new board. I was hoping to find a service manual so I could confirm the components & poke around with a meter. I also see the board is out of stock till next week at least.
Many Thanks Again!
Gene
<<<So my understanding is that this type a failure IS "Unusual" and you wouldn't expect another bad component elsewhere>>>
Correct.
There are no Service Bulletins to indicate a problem with the MAIN BOARD on this washer (and I've never seen this type of failure as well)
<<<I would expect their labor charges several times more than your quoted board cost>>>
The LABOR rate for this repair is at the discretion of each authorized LG service center.
Likely to be in the range of $85 to $195.
<<<Hoping I don't fry the new board>>>
I am confident that this is not a concern at all.
<<<I also see the board is out of stock till next week at least.>>>
RepairClinic is out of stock on this part.
It is in-stock at LG Parts Dept.
In your case---having dealt with someone at LG (and not a pleasant one)---it can be frustrating having to order the MAIN BOARD from them given that it is a "covered" part (limited part warranty).
In order to qualify for this part replacement---an authorized LG servicer must verfiy that the MAIN BOARD has indeed failed.
This is the normal procedure for most manufacturers.
The downside (in your case) is that the servicer must be paid labor charges to obtain & install the part(s).
This is done---by the way---to ensure that the *correct* failed part is replaced AND to eliminate guess-work or outright fraud (ordering parts---even though it is not needed).
