jrlead
Washer will not drain
5 posts in this topic
Washer will not drain, Checked the pump and it is working. Hose is not clogged
... what else is there ?
Thanks for the non answer
You've got to be missing something. If everything is as you say-- pump working and hose not clogged-- then the washer will drain. That's the way physics works in our Universe.
We're not there at the appliance to physically diagnose it for you-- we rely you to tell us what's happening or not happening. Garbage in, garbage out.
Some thought questions for you:
- have you measured the supply voltage to the pump when it should be running?
- have you blown through the drain hose starting from the pump end of the hose?
- have you removed the suction boot from the pump and checked it for panties, socks, etc?
- with the suction boot removed, have you poured some water into the drum to see if it drains right thru the detached suction boot?
