New Appliance Service Manual added: KitchenAid Double Wall Oven Electric
File Name: KitchenAid Double Wall Oven Electric
File Submitter: kdog
File Submitted: 28 Apr 2012
File Category: Appliance Repair Manual Pot Luck Supper
KitchenAid Electric Built In Double Wall Oven
Job Aid
SPECIFICATIONS .................................................................................................................. 1-1
INSTALLATION HIGHLIGHTS................................................................................................ 2-1
Electrical Supply Requirements ......................................................................................... 2-1
Removing & Reinstalling The Oven Door .......................................................................... 2-3
PRODUCT OPERATION ........................................................................................................ 3-1
Air Flow .............................................................................................................................. 3-1
The Oven Shutdown Thermal Fuse & Control Panel Thermal Fuse ................................. 3-2
The Oven Door Latch Assembly ........................................................................................ 3-3
How The Self-Clean Cycle Works ..................................................................................... 3-4
COMPONENT ACCESS ......................................................................................................... 4-1
Component Locations ........................................................................................................ 4-1
Removing The Thermal Fuse, The Oven Control/Display Boards,
And The Touch Panel Assembly .................................................................................... 4-2
Removing The Power Supply Wiring Terminal Block
And The Upper & Lower Blower Motors ......................................................................... 4-4
Removing The Upper & Lower Oven Door Latch Assembly.............................................. 4-6
Removing An Oven Light & An Oven Temperature Sensor .............................................. 4-8
Removing A Broil Element ................................................................................................. 4-9
Removing A Bake Element .............................................................................................. 4-10
Removing An Oven Shutdown Thermal Fuse ................................................................. 4-11
Removing The Convection Fan Motor Assembly ............................................................ 4-12
Removing The Oven Door Glass, Hinges, & Handle ....................................................... 4-14
Removing The Oven Door Gasket................................................................................... 4-16
COMPONENT TESTING ........................................................................................................ 5-1
Blower Motors .................................................................................................................... 5-1
Oven Temperature Sensor ................................................................................................ 5-1
Convection Fan Motor ....................................................................................................... 5-2
Oven Shutdown Thermal Fuse .......................................................................................... 5-2
Broil Element ..................................................................................................................... 5-3
Bake Element .................................................................................................................... 5-3
Oven Door Latch Assembly ............................................................................................... 5-4
Control Panel Thermal Fuse .............................................................................................. 5-4
DIAGNOSIS & TROUBLESHOOTING.................................................................................... 6-1
Diagnostics ........................................................................................................................ 6-1
Fahrenheit To Celsius Conversion .................................................................................... 6-1
Programming The Cavity Size ........................................................................................... 6-1
Electrostatic Discharge Sensitive Electronics .................................................................... 6-1
Failure/Error Display Codes—Tech Sheets 4451887C & 4451888A ................................ 6-2
Failure/Error Display Codes—Tech Sheet 4452022A ....................................................... 6-3
Relay Logic Chart—Tech Sheets 4451887C & 4451888A ................................................ 6-4
Relay Logic Chart—Tech Sheet 4452022A ....................................................................... 6-4
Control Panel Test Locations—Tech Sheets 4451887C & 4451888A .............................. 6-5
Control Panel Test Locations—Tech Sheet 4452022A ..................................................... 6-6
- iv -
WIRING DIAGRAMS & STRIP CIRCUITS.............................................................................. 7-1
Schematic Diagram 1 (Tech Sheet 4451887C) ................................................................. 7-1
Strip Circuits ...................................................................................................................... 7-2
Schematic Diagram 2 (Tech Sheet 4451888A) ................................................................. 7-4
Strip Circuits ...................................................................................................................... 7-5
Schematic Diagram 3 (Tech Sheet 4452022A) ................................................................. 7-7
Strip Circuits ...................................................................................................................... 7-8
Tech Sheet / Model Number Usage Charts ..................................................................... 7-10
Click here to download this file
