LG WM2455HG Front Load Washer
1 reply to this topic
#1 gdoggy
gdoggy
  • 8 posts
Posted 29 April 2012 - 03:21 PM
I'm having a few intermittent problems with my LG front loader. First the history of problems/repairs - really minor. I had the display assembly replaced under warranty about 1.5 years ago due to a garbled display. Since then no issues until now. I noticed a few times during cycles that the countdown display would be blank. The cycles would all complete normally even with no display. I don't watch the washer so I'm not sure how often it occurs. Since it hasn't affected the functioning, I've ignored it.
Now for the current issue.... I've noticed a few times that during the speed wash specifically that the countdown timer starts at 20 minutes, but it seems to be doing unnecessary agitating and spinning so I checked on it. The display would be stuck at 7 minutes remaining and stays like that for quite some time. Eventually after about 30 minutes of what I would consider excessive spinning it would just do the completion tone and turn off. All appears normal as far as the clothes being clean, no detergent or softener left in the cups, etc. Is this normal, or is something wrong?
#2 john63
john63
  • 1,411 posts
Posted 29 April 2012 - 04:20 PM
<<< I noticed a few times during cycles that the countdown display would be blank.>>>
Possibly a failed DISPLAY BOARD.
http://www.repaircli...6870701/1369223
Verify first---that the plug connections *behind* the jog dial are not loose or that the wires are not chaffed.
To access these wires---unplug the washer and remove the top cover (of the washer).
<<< I've noticed a few times that during the speed wash specifically that the countdown timer starts at 20 minutes, but it seems to be doing unnecessary agitating and spinning so I checked on it. The display would be stuck at 7 minutes remaining and stays like that for quite some time.>>>
Usually caused by one or both of the following...
1) incorrect type or amount of detergent used. Excessive suds---can enter the AIR BELL at the rear of the washer. The WATER LEVEL SENSOR "thinks" that there's still water remaining in the tub---causing extended DRAIN MOTOR run time and delayed spin cycle (or aborted altogether).
Also---during any *rinse cycle* (about the middle of any cycle)---if suds is detected via the motor sensor---an LG washer will enter a software program called: "SUDS KILL MODE".
During "suds-kill" the display clock will stall/stop counting-down until the triggered suds-kill-program ends (about 30 minutes).
After which---the count-down clocks resumes.
2) Washer on weak wood floor or not leveled properly.
Add a single towel to the tub (to mimic an imbalanced condition)
Power on
Select the SPIN SPEED to "Extra High"
Press the START/PAUSE button
Wait until the *Time Remaining* displays "7"
Place a finger at each of the front leveled legs of the washer---as the tub begins to ramp-up to high speed---determine which of the front legs is beginning to "hop" off the floor.
Use the LG wrench (that is provided with each new washer) or an adjustable pliers tool to turn/level the washer leg until the "hopping/vibration" is minimized or stopped altogether---usually requires a 1/4 to 1/2 a turn.
Lock both leveling legs to prevent misalignment later.
Edited by john63, 29 April 2012 - 05:29 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
Countdown display on an LG front load washer goes blank
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 04 May 2012 - 01:59 PM
Possibly a failed DISPLAY...
Read Full Entry →
