jenn air downdraft range error codes EE-214 M-214
range
4 replies to this topic
#1 rmccline2
rmccline2
  • 3 posts
  • Flavorite Brew:pilsner urquel
Posted 30 April 2012 - 01:07 PM
I have a jenn air range that won't respond to front panel commands. Only displays time and two error codes.
Model JGS9900BDS.
#2 RegUS_PatOff
  • 30,689 posts
Posted 30 April 2012 - 02:25 PM
Has this Range worked OK for you up till now at this location ?
Have you recently used Self-Clean ?
#3 rmccline2
rmccline2
  • 3 posts
Posted 30 April 2012 - 03:04 PM
This unit worked in location for two years. Would sometimes lock up requiring power cycle.
Self clean has most likely never been done.
#4 rmccline2
rmccline2
  • 3 posts
Posted 09 May 2012 - 11:14 AM
I got the manual.
the manual shows that the control board needs pins 1 and 10 shorted by control panel to detect its presence.
Also many buttons on control panel don't ohm out.
new control panel fixed it.
#5 Trying to help
Trying to help
  • 2,464 posts
Posted 09 May 2012 - 01:45 PM
This is a fault code that never made it to the tech sheet. Faulty Touch Pad is the cure. I have it written in pen on my fault sheet so it has to be correct!!
FYI for our staff, that clock is in the wall oven line as well. Same thing will apply to any unit that uses that ATM style control. It is not in any publication.
If we saved YOU Beer $$ today, please make a donation to our beer fund by clicking the link below to help keep this site going. I charge $135.95 PLUS PARTS to do this repair!$! http://fixitnow.com/beerfund.htm
Jenn-Air downdraft range undocumented error codes EE-214 M-214
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 09 May 2012 - 02:20 PM
FYI for our staff, that clock is in the wall oven line as...
Read Full Entry →
