Whirlpool Duet Washer WFW9500TW03
bad bearings
9 replies to this topic
#1 rolandvz71
rolandvz71
    Sōhei
  • Chief Appliantologist
  • 198 posts
  • Flavorite Brew:Sweet Sun Tea w/lemon
Posted 30 April 2012 - 09:32 PM
Surprisingly the drum was fine and in great shape.....the bearings failed probably due to a bad seal.
OK I was able to salvage the mechanical seal's # (SP 50x10/106x10/13.5), but the bearings #'s were soo far gone I could not get any #'s off of them.......has any one tackled this problem?
THx!
Edited by rolandvz71, 03 May 2012 - 08:37 AM.
#2 rolandvz71
rolandvz71
    Sōhei
  • 198 posts
Posted 01 May 2012 - 06:39 PM
The inside seal is a Bit@H TO FIND!! I went to 5 different places and no luck!
Looks like I might have to buy it online...still have some feelers out there so I will give it to the end of the week.
Edited by rolandvz71, 03 May 2012 - 08:36 AM.
#3 rolandvz71
rolandvz71
    Sōhei
  • 198 posts
Posted 01 May 2012 - 08:54 PM
any1?
#4 rolandvz71
rolandvz71
    Sōhei
  • 198 posts
Posted 10 May 2012 - 09:17 PM
Bought the inside seal on line from this fella http://www.duetbearing.com/ fit like a glove thx!
#5 certified tech group 51
  • 1,977 posts
Posted 10 May 2012 - 11:38 PM
Sounds like the guy did his homework .....Any thing to improve the bottom line.... thax for the results ........... :thumbsup:
#6 rolandvz71
rolandvz71
    Sōhei
  • 198 posts
Posted 18 June 2012 - 09:25 AM
Yea I learned alot on this project:
1. How to read a caliper
2. Where to find cheap bearings locally
3. How to find cheaper tub seals.
4. How to replace a tub bearing (it was my 1st one)
Now the washer is up and running w/out any issues.
Edited by rolandvz71, 18 June 2012 - 09:26 AM.
#7 rolandvz71
rolandvz71
    Sōhei
  • 198 posts
Posted 16 October 2012 - 11:17 PM
Well guys and gals sorry to say water has worked past the seal........one of the bearing is starting to have a slight roar.
I dont know its the seal or the bearing.
I will be tearing into it in the coming days. I will keep you posted.
If it's the seal....... it only lasted less than 6 months
Edited by rolandvz71, 16 October 2012 - 11:18 PM.
#8 rolandvz71
rolandvz71
    Sōhei
  • 198 posts
Posted 22 October 2012 - 06:21 PM
Ok guys and gals I might have jacked the install of the bearing seal the 1st time so gonna need some input before I move forward.......As you can see the same type of seal came in thru a different vendor (Ebay ....$5). So now my question is did I install the seal wrong causing failure......??? Before you answer, the seal outer wall from what I remember is tapered (could be wrong) to accept the tub to match. So I do believe I did install the seal right but since this was my 1st bearing job human error maybe the contributing factor.
Thx all for the help
http://s225.photobuc...gs PART 2 redo/
Edited by rolandvz71, 22 October 2012 - 11:31 PM.
#9 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 22 October 2012 - 10:33 PM
I would have just replaced the whole rear half of the outer tub and been done with it without having any callbacks.
Scott Wolf
#10 rolandvz71
rolandvz71
    Sōhei
  • 198 posts
Posted 22 October 2012 - 11:30 PM
Actually this one is ours....I fig I would practice on our machine.
Plus when I can get BOTH bearings and the seal for less than $15 vs $80 from the site mentioned on post #4 and all I am out is my time and gain experience.... I'd say knowledge is power over these bearing problems.
Edited by rolandvz71, 23 October 2012 - 09:01 AM.
