#1
Posted 01 May 2012 - 10:49 AM
I have no manual or documentation for this dishwasher. Where should I start?
Thanks!
Rich
#2
Posted 01 May 2012 - 12:34 PM
then it's not Pumping out all of the Water ...... It pumps out the water at the end of the cycles
... but when it's done there's an inch or two of standing water in the bottom of the machine.
... it won't run again unless I unplug it for a couple minutes to let it rest.
check your Drains ..
may be time for a new Dishwasher
#3
Posted 01 May 2012 - 10:00 PM
This is the new dishwasher (for me)!
#4
Posted 01 May 2012 - 11:05 PM
It could be Drain water returning. ..
OR a leaky Fill Valve...
Is the Water dirty / soapy ?
#5
Posted 02 May 2012 - 07:18 AM
The standing water is clear, not dirty or soapy.
I don't think the problem is a valve because the dishwasher won't start again until I've unplugged it for a couple minutes. It seems like something is tripping a circuit breaker in the dishwasher near the start of the dry cycle.
#6
Posted 02 May 2012 - 09:06 AM
It's an old dishwasher
yes, it is
... may be time for a new Dishwasher
may be an over-heating Circulation Motor
(no longer available)
#7
Posted 02 May 2012 - 09:27 AM
Aside from the cost of replacing this dishwasher, I'd also have to haul it down 3 flights of stairs, dispose of it, and haul the new one up 3 flights, so it's not a real attractive option.
#8
Posted 05 May 2012 - 11:27 AM
I pulled the kick panel, hoping to see a schematic, or something obviously broken, but I didn't find that. I saw only one motor, which I guess drives everything. It's label says it's thermally protected, so I'm guessing that's what's humming and then shutting down until it has a cooldown period.
I took some pictures in case those help anyone tell me where to look next. Hopefully, this link will work for you: https://plus.google....086091791756801
#9
Posted 06 May 2012 - 06:54 AM
Remove the round belt from the motor then try to turn the pump pulley by hand, most likely you are going to find it hard to turn.
See if the motor will run OK with the belt off, (off course with the belt off the water won't circulate and it won't pump out either but you will then know if the motor will run without a load on it).
Do you of a clamp on amp meter? If you do, watch what the readings are when you first start it up and see if the amp reading starts to go higher the longer it runs and then spikes up real high just before it stops running, (most likely as you have already found from tripping the internal overload protector in the motor).
- Samurai Appliance Repair Man and Sparky1 like this
Eureka, CA 95501
#10
Posted 06 May 2012 - 09:32 AM
Also tagged with one or more of these keywords: dishwasher
