Kenmore HE4 Dryer 110.85081400 Control Locked Light Blinking and Beeping
8 replies to this topic
#1 rayzgurl
rayzgurl
  • 18 posts
Posted 01 May 2012 - 12:28 PM
No other controls will work when this is going on. It's a steady beep about 1 second apart, no pattern to it.
The only way to stop the beeping is to unplug it or turn off the circut breaker to the dryer. Sometimes I can plug it back in after an hour or so and it will work. But that doesn't always work.
Thanks in advance. Y'all have always been such a great help to me! :-)
#2 rayzgurl
rayzgurl
  • 18 posts
Posted 01 May 2012 - 01:30 PM
Oh, and it will just start beeping out of the blue. We'll be in bed and I'll wake up hearing it beeping.
    Shōgun
  • Master Samurai Tech
  • 30,703 posts
Posted 02 May 2012 - 07:00 AM
Take another look at the model number, you have a typo in the three-digit prefix.
#4 rayzgurl
rayzgurl
  • 18 posts
Posted 02 May 2012 - 07:46 PM
Sorry,
110.85081400
#5 certified tech group 51
  • 2,694 posts
Posted 02 May 2012 - 09:35 PM
What happens if you hold the 'control lock' button down for 3 to 5 seconds ???....... Or look for the little padlock symbol button(s).......................
#6 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 02 May 2012 - 11:54 PM
Corrected model in title;
Could be a stuck or messed up keypad on the touchpanel (the same key you hold for control lock as described above) - unplug when not in use to avoid the impromtu 2a.m. alarm
#7 rayzgurl
rayzgurl
  • 18 posts
Posted 03 May 2012 - 06:55 AM
Sensei, Nothing happens when I hold down the control lock buttun, non of the controls work when this is going on.
Sometimes I can plug it back in, hold down the control key and it will stop beeping, but this does not work every time and I'm afraid to wash anything now because I don't want to be stuck with wet clothes and a dryer that won't work. Laundry mats around here are few and far between and the ones we do have are in questionable neighborhoods. :ermm:
    Shōgun
  • 30,703 posts
Posted 03 May 2012 - 07:03 AM
You have a bad touchpanel. Not uncommon in these dryers. Come pick your flavorite color ==> http://www.repaircli...-Touchpad-Parts
#9 rayzgurl
rayzgurl
  • 18 posts
Posted 03 May 2012 - 09:37 AM
OH awesome! NOT!
I figured that was the problem, but was hoping maybe not. UGH! Better than getting a new dryer.
Any link to instructions on how to replace it? I'm sure it's probably "Plug N Play" easy, but figured I'd ask.
Thanks!
Samurai!
