Kenmore 70 Series Washer - Random Rinse Cycle Issues
Kenmore 70 Series Washer Rinse Cycle
5 replies to this topic
#1 Darrel Rogers
Darrel Rogers
  • 3 posts
  • Flavorite Brew:Budweiser Platinum
Posted 02 May 2012 - 05:00 PM
Half of the time at the end of the Rinse Cycle, some combination of the 3 things (drain, spin, spray) that are supposed to happen do not. I thought it might be the timer contacts, but I am just guessing.
The pump, spin and agitate work correctly during the wash stages - the random problems are isolated to the end of the rinse stage.
Any guidance is greatly appreciated.
Kenmore 70 Series - Model # 11020702990
#2 RegUS_PatOff
  • 30,708 posts
Posted 02 May 2012 - 08:17 PM
Normal operation:
1) Agitates . . . . then
2) maybe pauses, maybe soaks . . . . then
3) Pumps out . . . . then
4) after Pump-out, Timer pauses the Washer Motor for a few seconds (can be simulated by lifting the Lid) . . . then
5) Spin starts
#3 Darrel Rogers
Darrel Rogers
  • 3 posts
Posted 03 May 2012 - 09:20 AM
Thanks for the reply. It's at steps 3, 4 and 5 that are not working correctly.
Sometimes in drains, pauses, spins, sprays and continues to spin out the clothes as it should.
Half the time though the timer moves as it should, but steps 3-5 do not happen correctly.
  • Sometimes it won't drain, spin or spray, but makes noise like it is doing something.
  • Sometimes it will drain, but not spin or spray.
  • Sometimes it will drain and spin, but not spray.
As I have watched a number of washes now, the wash part works without fail - it is isolated to the end of the rinse cycle.
In my research, it appears there are 3 possibilities (timer-$130, lid switch-$15, motor-$180). How to narrow this down to the right solution?
#4 RegUS_PatOff
  • 30,708 posts
Posted 03 May 2012 - 10:35 AM
... but makes noise like it is doing something.
what "makes noise" ?
#5 Darrel Rogers
Darrel Rogers
  • 3 posts
Posted 03 May 2012 - 10:51 AM
Now that I have said that about the noise and you called me on it, let me step that statement back. The noise is the pump draining in scenario 2.
The scenarios should have read like this:
  • Sometimes it won't drain, spin or spray.
#6 RegUS_PatOff
  • 30,708 posts
Posted 03 May 2012 - 11:05 AM
sounds like a bad Timer
http://www.repaircli...?R=154&N=829648
Also tagged with one or more of these keywords: Kenmore, 70 Series, Washer, Rinse Cycle
