kevinmac6591
sears model number 363.58067890
3 posts in this topic
icemaker dispenses crushed ice only no cubes. looked at exploded view of dispenser/bucket on sears.com but not sure what parts i need to replace to get cubes. any ideas appreciated.
Not unusual for the solenoid actuator for the metal arm of the icetray auger to seize up. It is located above the actuator stirrup at the back of the freezer - the actuator pin gets froze up and seizes and the solenoid melts down. Part Links below:
http://www.repairclinic.com/PartDetail/Solenoid-Collar/WR17X1065/293025?modelNumber=363.58067890
http://www.repairclinic.com/PartDetail/Crushed-Cubed-Ice-Solenoid/WR17X1064/293024?modelNumber=363.58067890
Crushed-Cubed-Ice-Solenoid-WR17X1064-011
http://www.repairclinic.com/PartDetail/Crushed-Cubed-Ice-Solenoid/WR62X58/2390?modelNumber=363.58067890
Crushed-Cubed-Ice-Solenoid-WR62X58-00880
Sometimes the ice bin rod gets out of position with the yoke at the rear of the bin.
Open the freezer door and look underneath the ice bin.
You will see the metal rod going into the opening for the solenoid in the back wall.
The rod must be IN not under the yoke.
If it is not IN,pull the bin out then push it back in so that the rod is IN the yoke.
