Dishwasher tub crack repair
5 replies to this topic
#1 weswayne
weswayne
    Senpai
  • Chief+ Appliantologist
  • PipPipPipPip
  • 922 posts
  • Flavorite Brew:Coke
Posted 05 May 2012 - 07:19 PM
Somehow the heating element has caused a burn mark in the tub of the dishwasher. A very small hairline crack has developed. It is about 1/4" long but water is leaking through enough to cause a problem. I needed to know what specific type of high temperature epoxy to buy or any other solutions would be welcome. I am familiar with using a gasket and screw but would really like to avoid making the crack worse by driving a screw through the tub.
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 05 May 2012 - 08:46 PM
Ten Commandments for Reading Appliance Model Numbers :)
Posted Image Posted Image Posted Image
Only repair I am aware of is a new tub
#3 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 06 May 2012 - 07:13 AM
A high temp RTV sealant will work.
    Shōgun
  • Master Samurai Tech
  • 31,415 posts
Posted 06 May 2012 - 07:24 AM
Does this crack originate from the entry hole for the heating element or is it somewhere else?
#5 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,580 posts
  • Flavorite Brew:What's on tap?
Posted 06 May 2012 - 09:43 AM
There are a few models that have been recalled for this problem. So, as Kdog pointed out, the model number would sure help...
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect nor represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#6 weswayne
weswayne
    Senpai
  • PipPipPipPip
  • 922 posts
Posted 06 May 2012 - 12:54 PM
Model # DU1100XTPQ6
Serial # FS5213477
The tub is still under warranty so the next step is to see if Whirlpool will step up and actually get these people a new tub.
Thank you for all your responses.
