weswayne
Dishwasher tub crack repair
6 posts in this topic
Somehow the heating element has caused a burn mark in the tub of the dishwasher. A very small hairline crack has developed. It is about 1/4" long but water is leaking through enough to cause a problem. I needed to know what specific type of high temperature epoxy to buy or any other solutions would be welcome. I am familiar with using a gasket and screw but would really like to avoid making the crack worse by driving a screw through the tub.
A high temp RTV sealant will work.
Does this crack originate from the entry hole for the heating element or is it somewhere else?
There are a few models that have been recalled for this problem. So, as Kdog pointed out, the model number would sure help...
Model # DU1100XTPQ6
Serial # FS5213477
The tub is still under warranty so the next step is to see if Whirlpool will step up and actually get these people a new tub.
Thank you for all your responses.
