GE gds20sbsass not cooling after mainboard service
12 replies to this topic
#1 stylgc
stylgc
  • 13 posts
Posted 06 May 2012 - 05:24 PM
Hopefully someone can help-
Initial problem>clicking mainboard.So I replaced the relay and capacitors on the mainboard for this refrigerator-no clicking. Refrigerator has been left in storage for 18+months. I just installed the repaired mainboard, I turned the refrig temp dials up to max>I hear the compressor running and left it running for an hour. There is no cooling. I adjusted the temp controls and the compressor clicks on off with these adjustments but again, there is no cooling. Please help.
#2 kdog
    RoughShod
  • 7,466 posts
Posted 06 May 2012 - 05:39 PM
Sounds like a sealed system issue - remove rear cover on freezer and check for frost pattern on coils while compressor runs
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 06 May 2012 - 05:51 PM
NO cooling ?
Have you looked directly at the frost pattern of the Evaporator Coils inside the Freezer ?
It may take up to 24 hrs or more for the Fridge / Freezer to reach optimum temperatures
#4 stylgc
stylgc
  • 13 posts
Posted 08 May 2012 - 05:58 PM
Hi-
waited 24hrs- Bottom freezer is cooling OK, Refrigerator is not at all-steady at 20 degrees celcius. Removed rear panel and there is no ice build up on the coils or in the freezer compartment. compressor is continually running and I have not seen the fan by the coils turn on either. Any help would be appreciated.
Edited by stylgc, 08 May 2012 - 11:37 PM.
#5 RegUS_PatOff
  • 33,588 posts
Posted 08 May 2012 - 07:04 PM
... frost pattern of the Evaporator Coils inside the Freezer ?
#6 stylgc
stylgc
  • 13 posts
Posted 08 May 2012 - 11:18 PM
Sorry-
Attached is a photo that describes the frost pattern on the evaporator coils in the freezer. Freezer is set to midrange(5) on the dial and has
been plugged in for 2 days.
Attached File  GE.JPG   129KB   15 downloads
Edited by stylgc, 08 May 2012 - 11:31 PM.
#7 RegUS_PatOff
  • 33,588 posts
Posted 09 May 2012 - 05:05 AM
looks OK,
Does the Freezer Evaporator Fan run anytime the Compressor runs
(and the Freezer Door Switch is closed)
#8 stylgc
stylgc
  • 13 posts
Posted 09 May 2012 - 01:25 PM
No-I have never seen the freezer evaporator coil fan run-I tried opening the freezer and closing the freezer door switch and it will not run.
#9 RegUS_PatOff
  • 33,588 posts
Posted 09 May 2012 - 01:30 PM
... I have never seen the freezer evaporator coil fan run-I tried opening the freezer and closing the freezer door switch and it will not run.
... and the Compressor was running ?
then it's either a bad Evaporator Fan or MotherBoard
#10 stylgc
stylgc
  • 13 posts
Posted 09 May 2012 - 01:36 PM
Compressor is running almost constantly and the fan is not running.
    Shōgun
  • Master Samurai Tech
  • 30,189 posts
Posted 09 May 2012 - 07:00 PM
Check the voltage to the evaporator fan motor. This page explains ==> https://docs.google....eICe1_KrVg/edit
Can also try running the fan off a 9vdc battery (see link above).
If the fan runs off the battery, then replace the muthaboard ==> http://www.repaircli...ber=GDS20SBSASS
If the power supply to the fan is good, replace the fan ==> http://www.repaircli...ber=GDS20SBSASS
#12 stylgc
stylgc
  • 13 posts
Posted 09 May 2012 - 09:37 PM
I have another new motherboard so I thought I would install it first before I test the fan. It is a WKKT 0158-00-04
gea part#200D4854G013 no model# written on it. I installed it an noticed the compressor is not running and the fan at the rear of the fridge is turning a quarter turn slowly and the fan inside the freezer by the evap coils is trying to turn-vibrating back and forth. The motherboard is making a quiet "clock ticking" sound. I was told this board could be used with my refrigerator, but now I need to ask, is his compatible with my
gds20sbsass refrigerator?
Edited by stylgc, 09 May 2012 - 11:51 PM.
#13 RegUS_PatOff
  • 33,588 posts
Posted 10 May 2012 - 05:41 AM
... I have another new motherboard so I thought I would install it first before I test the fan.
... compatible with my gds20sbsass refrigerator?
1) NOT a good idea. A bad Fan Motor can ruin the MotherBoard
2) compatible, yes, but must follow installation instructions. Some models need wire connections cut.
