#1
Posted 07 May 2012 - 09:09 PM
IgonFishn & Tight Lines
#2
Posted 07 May 2012 - 09:50 PM
Edited by Bullstok, 07 May 2012 - 09:52 PM.
#3
Posted 07 May 2012 - 11:17 PM
$800 for work that I can do but don't have a license to...That hurts......I did diagnose the problem...Made it easy for the tech...Price war? (See AC not cooling blog) just want to know if the rate is reasonable.
Any way back to this blog's focus...the ice problem...customer's refer...She called me this evening...Ice is coming out her ears...she had to turn the water valve to the ice maker to stop the er had this problem icebergs...Never had this repair problem before...Preliminary diagnostic...switch fused close? ,,,Infra red stuck open?...parts houses show just parts to replace, not the complete unit (10 year ice maker), I would replace complete unit not rebuild it...Any way I am looking for anybodies else experience with this particular problem...Want to repair when I make the call, I provide honest, dependable, reasonably, price service...That's my Business core focus. Any tech that has wants to share their honest advice will be greatly appreciated. Thank you.
#4
Posted 07 May 2012 - 11:40 PM
#5
Posted 09 May 2012 - 08:12 PM
This ice maker is sitting in freezer sideways. Has 7 cubes instead of 8. Does not mount on side wall. Mounts on top wall of freezer. Can not access the front module with out taking it down. Bucket sits in door. Did I mention it's a ice making machine.
Here is the problem Has a light emitter that opens & closes the circuit. The off switch just obstructs the light beam, As so a flapper when freezer is opened or ice bucket fills with ice.
Has P.C. Board Receiver (2198586), on right side wall of freezer liner; P.C. Board Emitter (2198585).
question? How do I test the 2 P.C. boards to determine which one is defective or do I just replace both. Also I would like to know how to detect the light beam, (sure it is infra red) if it is working, seems I read somewhere you can use a camera to check the beam of a remote tuner.
#6
Posted 09 May 2012 - 08:32 PM
#7
Posted 09 May 2012 - 11:42 PM
that is not the correct ice maker. This ice maker is sitting in freezer sideways. Has 7 cubes instead of 8.
There are only 2 of these style icemakers, a 5-cube and an 8 cube
- Samurai Appliance Repair Man and RussTech like this
#9
Posted 14 May 2012 - 08:42 PM
#10
Posted 19 May 2012 - 07:44 AM
- kdog likes this
#11
Posted 19 May 2012 - 11:14 AM
#12
Posted 19 May 2012 - 01:04 PM
Did you do the T to H jumper test in the icemaker module to see if the icemaker manually harvests?
Yes I did, Unit did not initiate Harvest cycle.
That's a bad control module. You're better off just replacing the whole icemaker. Grand Master kdog called the dance steps on this one early on.
- kdog likes this
#13
Posted 29 May 2012 - 10:36 PM
My customer with the icemaker that makes & makes ice when the emmitter board was malfunctioning, not sending an light beam, it should not work, correct. Then after installing new emmitter the ice maker quits making ice. Now after a week of sitting there lifeless the I/M has started to act normal. I/M is working perfect. Fills the ice bucket then shuts down when full. Go figure.
#14
Posted 30 May 2012 - 05:21 AM
#15
Posted 01 June 2012 - 12:05 AM
. Who knows how much door openings and fiddling they did with it.
Also tagged with one or more of these keywords: Ice maker
