Ge Washer wont spin
ge washer motor replacement WVSR1060B3ww Whdsr315daww
7 replies to this topic
#1 Tburys
Tburys
  • 15 posts
Posted 07 May 2012 - 09:46 PM
I have a Ge washer Model Number WVSR1060B3ww. The washer works fine ecept the spin cycle. During the spin Cycle the motor does nothing at all. I assume that the motor is bad.....
With that assumption i took a motor out of a model Whdsr315daww and put it in the for the broken model. I matched wires up color for color, but no luck. The motor just hums....
I am attaching the schematics for both washer models.... Please help me out.
Cant attach files because it says file to big... I can email them i guess/>
Casey
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 May 2012 - 10:12 PM
... During the spin Cycle the motor does nothing at all...
... The motor just hums....
... Cant attach files because it says file to big
... WVSR1060B3ww
... Whdsr315daww
1) no Motor noise ?
2) hums in Agitate and Spin ?
3) post files somewhere else, then post link
4) one speed Motor
5) two speed Motor
#3 Tburys
Tburys
  • 15 posts
Posted 07 May 2012 - 10:38 PM
http://s1153.photobu...washer diagram/
Link to pics of diagrams
Response to Regus_patoff
1.No Motor noise on the original motor during spin cycle.
2. With the new motor I get a hum during agitate and nothing during spin.
I think the first motor was one speed and the second is two speed but im not sure.
#4 RegUS_PatOff
  • 33,588 posts
Posted 07 May 2012 - 11:10 PM
... WVSR1060B3ww
... Whdsr315daww
4) one speed Motor
5) two speed Motor
bad Timer
http://www.repaircli...?R=154&N=947875
#5 Tburys
Tburys
  • 15 posts
Posted 09 May 2012 - 03:48 AM
Not to be rude..... I was hoping for a little more insight than two words to solve the problem.
Why do you think it is the timer?
Is there a way to test the timer?
For example when the timer gets to spin cycle can i test the lead coming out of the timer for some resistance or voltage?
Is the second motor that I hooked up wired correctly?
#6 RegUS_PatOff
  • 33,588 posts
Posted 09 May 2012 - 05:12 AM
... Why do you think it is the timer?
... Is there a way to test the timer?
.. Is the second motor that I hooked up wired correctly?
1) if the Washer Agitates OK, the Motor is good
2) it's either a bad Motor or bad Timer (see above)
3) wiring looks OK, but putting a (2) speed Motor into a (1) speed Washer, the Motor willl start-jerk-start, etc ..
#7 Tburys
Tburys
  • 15 posts
Posted 09 May 2012 - 12:55 PM
Going to get a timer and try it.....
No way to test that old timer though?
#8 RegUS_PatOff
  • 33,588 posts
Posted 09 May 2012 - 01:27 PM
if it Agitates OK but no Motor noise in Spin ,
bad Timer
