Thermador C302UB double oven service manual and F33 error code
1 reply to this topic
#1 roberto
roberto
    Yamabushi
  • Chief Appliantologist
  • 74 posts
  • Flavorite Brew:sam adams
Posted 08 May 2012 - 10:16 AM
We are hoping that someone could point us to a service manual for a Thermador C302UB double oven. We are battling an intermittent F33 error code and and other issues. as always, thanks for your help.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 May 2012 - 10:26 AM
F33 Upper Oven Over Temperature While Cooking.
1. Power To The Oven Was Turned On When Temperature Inside Oven Is Over 550 F.
2. Intermittent Temperature Sensor Or Power/Relay Board.
1. Allow oven to cool below 550 F before turning power on.
2. Check header P3 on the powerlrelay board. Check resistance of upper oven sensor
(approximately 1080 ohms at room temperature).
If sensor is OK, replace power/relay board.
Check header P3 on the power/relay board.
92-02-025A Thermador Built-In Oven C Service Manual.pdf
link PM'd
