Whirlpool VMW washer - no agitate, no spin WTW5640XW0
whirlpool VMW washer
11 replies to this topic
#1 Samurai Appliance Repair Man
  • 24,346 posts
Posted 08 May 2012 - 12:42 PM
Hi guys, my turn again!
I'm working on a Whirlpool Vertical Modular Washer. Complaint: no agitate, no spin. I verified the complaint: washer will fill and drain but won't agitate or spin.
Basket turns freely, main drive pulley attached, nut tight, belt intact.
Putting the machine into diagnostic mode, I get error code F7 E1 - not basket movement detected. Not very illuminating.
Removed/reseated all motor and mode shifter wire harness connections down below. Removed/reseated mode shifter harness connector at main board.
Green LED was lit on main control board.
Mode shifter motor resistance checked good. But no 120vac measured (with harness connected) for mode shifter motor at J16:1-2
While I could enter diagnostic mode, I could not get the machine into the mode for manual spin or agitate according to this procedure:
Never got the Spin and Done LEDs to light up.
So, my first trip troubleshooting was inconclusive and I've got to go back. What else can I do to nail down the problem?
Domo!
#2 RegUS_PatOff
  • 30,278 posts
Posted 08 May 2012 - 03:06 PM
.. While I could enter diagnostic mode,
Successful activation of Diagnostic Test Modes will be indicated by all status LEDs
(except for Lid Locked) flashing ON and OFF in half-second intervals.
correct ?
  • 24,346 posts
Posted 08 May 2012 - 03:25 PM
That's affirmative, Brother Reginald. And it was in that mode that I got the error code, F7 E1. What I could not do was to get into the manual test mode from there.
#4 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 08 May 2012 - 06:44 PM
Book isn' t much help on this. I would go after the door switch/lock assembly. Will this design machine fill and drain with the lid open normally?
  • 24,346 posts
Posted 08 May 2012 - 07:08 PM
Howdy, NCA. No, the design of this beast is that the door lock has to be engaged before it will even fill or drain. When it goes to agitate, you hear this grinding sound-- motor runs but it grinds like a rip saw. Shoulda gotten a video of that. Dang it! Almost seems like a bad transmission. Going back on Thursday to do more shootin then.
Edit: My video got boogared up. New upload pending now.
#6 NCARepair
NCARepair
    Sōhei
  • 202 posts
Posted 08 May 2012 - 07:27 PM
Ok,admit i have not seen one yet. I yearn for the belt drive days with broken cam bar pins and wig-wags. The original post led me to believe nothing was turning on agitate/spin wise. Electrically all is well i guess,must be mechanical. I would pull the splutch and see if it is broken,if ok then the gearcase.
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 08 May 2012 - 07:32 PM
Seems I had one making that grinding noise ....the splines where the basket mounts on the gearcase shaft had shat the bed...
Been getting some strange problems on these things. I don't have high hopes for these things long term...
Edited by KurtiusInterupptus, 08 May 2012 - 07:35 PM.
  • 24,346 posts
Posted 08 May 2012 - 07:44 PM
Yep, that was gonna be my next Ex-Lax move. Domo for the confirmation! :)
Here's the video of (most) of what I did today...
Domo, Brother Kurtius! What'd the fix turn out to be on this one?
#9 mark mac
mark mac
    Sōhei
  • 190 posts
Posted 08 May 2012 - 08:03 PM
if it's makin a grindin noise u need a tranny plastic gears in that transfer shaft
  • 24,346 posts
Posted 08 May 2012 - 08:11 PM
Domo Brother mark mac. Yep, it sounded like someone was snoozing and cuttin' zzzz's (but breathing fast).
#11 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 08 May 2012 - 09:47 PM
Had to replace the gearcase (shaft ) and the spline hub on the basket...
#12 Samurai Appliance Repair Man
  • 24,346 posts
Posted 10 May 2012 - 03:19 PM
Went back out today and here's a video of what I saw. In light of the illuminating comments from Brothers Kurtius and mark mac, it seems to be a bad transmission or the shaft/spline problem. Sound right to you, mah bruvahs?
Also tagged with one or more of these keywords: whirlpool, VMW, washer
