Roper RED4440VQ1
#1
Posted 08 May 2012 - 01:42 PM
I have a Roper RED4440VQ1 that is about 2 years old. Recently, the dryer stopped producing heat. I thought it might be the heating element until today when I tried to put it on the "High Heat 30 Minute Load" to tumble. When I took the clothes out, they were warm, so therefore the heating element and fuse must be working. What other problem could it be? Any help will be appreciated.
Thanks.
#2
Posted 08 May 2012 - 03:11 PM
could be a bad Timer
May need to try different tests / cycles
#3
Posted 08 May 2012 - 03:59 PM
#4
Posted 08 May 2012 - 04:05 PM
1) just double-check the symptoms ... if the Heater circuit works at all. chances are it's a bad Timer... How would I test to see if it's the timer?
... Is it difficult to replace myself?
2) just "plugs-in"
Part number: W10185972
