Maytag coin Stack Laundry-Noisy Dryer MLG19PDAWW
1 reply to this topic
#1 njames2
njames2
  • 8 posts
Posted 09 May 2012 - 01:06 AM
The dryer is noisy when it spins. What would you suggest needs to be done to make it function quietly when it turns?
#2 jumptrout
jumptrout
  • 1,380 posts
  • Flavorite Brew:Coors Light
Posted 09 May 2012 - 05:46 AM
Check the blower wheel. It could be stripped.
Check and clean the drum roller shafts.
Check and clean the tension roller shaft.
Check the front drum glides.
Replace the belt.
