Ge Profile Dryer Gas (propane) Model #dpsr473gw0ww Won't start
dpsr473gw0ww Ge Dryer Gas Propane wont start
4 replies to this topic
#1 Tburys
Tburys
  • 15 posts
Posted 09 May 2012 - 01:01 PM
My Ge Profile Dryer Gas (propane) Model #dpsr473gw0ww won't start. I press the start button and it sounds like its starting but when I let go of the button it stops. So it has power and wants to work but only when I hold the start button down. It doesn't seem to be tumbling when I hold the button down.
Thanks!
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,917 posts
  • Flavorite Brew:Killians Red
Posted 09 May 2012 - 01:05 PM
have someone hold the door switch and rotate the drum by hand while pressing the start button...
if it starts then...bad motor.
#3 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 797 posts
  • Flavorite Brew:yeunling
Posted 09 May 2012 - 06:06 PM
check the belt, i think some ge's will run with the start button pushed but stop when released if the belt switch is activated
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 May 2012 - 07:38 PM
.. ahh.. yes, correct
I found a similar wiring diagram... DPSR483
#5 Tburys
Tburys
  • 15 posts
Posted 10 May 2012 - 02:08 AM
Ok it was the belt and the idler pulley wheel, both were bad. There was a kill switch on the idler pulley arm that kills the power if there is no tension.
Thanks!
