Maytag Neptune MLG2000AWW Won't Compleatly Drain
3 replies to this topic
#1 vineman
vineman
    Yamabushi
  • Chief Appliantologist
  • 96 posts
  • Flavorite Brew:Priorat
Posted 10 May 2012 - 03:52 PM
Pump works good but leaves water sloshing about in the outer tub. I've ruled out siphoning because water is present as soon as the spin cycle ends. I'm not so sure what controls that function (sensor or board)? Maybe I'm missing the obvious but...thanks for the help.
#2 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 10 May 2012 - 04:00 PM
If the customer is rotating the laundry basket by hand---and is concerned because he/she hears liquid "sloshing"---this is normal.
Maytag Neptune-style washers used a liquid-filled balance ring on the stainless steel tub.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 May 2012 - 04:24 PM
can you see the Water ?
Are the clothes sopping, dripping wet ?
#4 vineman
vineman
    Yamabushi
  • 96 posts
Posted 10 May 2012 - 04:56 PM
No standing water in the basket and no complaints other than the sloshing sounds recently observed by customer. I think john63 has cut to the chase on this one. I am less familiar with this Neptune characteristic and appreciate the succinct and humane responses. :whistling:
